Parser errors
Posted: Tue Sep 23, 2014 1:17 pm
by p-i-
I'm getting a parser error:
void test_python()
#if MICROPY_ENABLE_GC
    // Heap size of GC heap (if enabled)
    // Make it larger on a 64 bit machine, because pointers are larger.
    long heap_size = 128*1024 * (sizeof(mp_uint_t) / 4);
    char *heap = malloc(heap_size);
    gc_init(heap, heap + heap_size);
#endif
    mp_init();
    do_str("print ( 'hello world!' )  \n");
void do_str(const char *src) {
    printf("%d\n", (int)strlen(src));
    mp_lexer_t *lex = mp_lexer_new_from_str_len(MP_QSTR__lt_stdin_gt_, src, strlen(src), 0);
    if (lex == NULL) {
        return;
    mp_parse_error_kind_t parse_error_kind;
    mp_parse_node_t pn = mp_parse(lex, MP_PARSE_SINGLE_INPUT, &parse_error_kind);
    if (pn == MP_PARSE_NODE_NULL) {
        // parse error
        mp_parse_show_exception(lex, parse_error_kind);
        mp_lexer_free(lex);
        return;
    // parse okay
    qstr source_name = mp_lexer_source_name(lex);
    mp_lexer_free(lex);
    mp_obj_t module_fun = mp_compile(pn, source_name, MP_EMIT_OPT_NONE, true);
mp_obj_t mp_compile(mp_parse_node_t pn, qstr source_file, uint emit_opt, bool is_repl) {
    compiler_t *comp = m_new0(compiler_t, 1);
    comp->source_file = source_file;
    comp->is_repl = is_repl;
    // optimise constants
    mp_map_t consts;
    mp_map_init(&consts, 0);
    pn = fold_constants(comp, pn, &consts);
// this function is essentially a simple preprocessor
STATIC mp_parse_node_t fold_constants(compiler_t *comp, mp_parse_node_t pn, mp_map_t *consts) {
    if (0) {
        // dummy
#if MICROPY_COMP_CONST
    } else if (MP_PARSE_NODE_IS_ID(pn)) {
        // lookup identifier in table of dynamic constants
        qstr qst = MP_PARSE_NODE_LEAF_ARG(pn);
        mp_map_elem_t *elem = mp_map_lookup(consts, MP_OBJ_NEW_QSTR(qst), MP_MAP_LOOKUP);
        if (elem != NULL) {
            pn = mp_parse_node_new_leaf(MP_PARSE_NODE_SMALL_INT, MP_OBJ_SMALL_INT_VALUE(elem->value));
#endif
    } else if (MP_PARSE_NODE_IS_STRUCT(pn)) {
        mp_parse_node_struct_t *pns = (mp_parse_node_struct_t*)pn;
        // fold some parse nodes before folding their arguments
        switch (MP_PARSE_NODE_STRUCT_KIND(pns)) {
switch (MP_PARSE_NODE_STRUCT_KIND(pns)) is giving EXC_BAD_ACCESS
If I try without the brackets, i.e. print 'hello world!' instead of print ( 'hello world!' ) (which should be valid Python I think -- it works on my commandline Python) and uncomment:
#define USE_RULE_NAME (1)
I get the following output:
rule: simple_stmt
File "<stdin>", line 1, column 0
SyntaxError: invalid syntax
Is there a single problem underlined both of these errors?
Re: Parser errors
Posted: Tue Sep 23, 2014 2:36 pm
by blmorris
p-i- wrote:If I try without the brackets, i.e. print 'hello world!' instead of print ( 'hello world!' ) (which should be valid Python I think -- it works on my commandline Python)
Are you using Python2 as your command line Python? Micropython implements Python3 syntax (I believe targeting 3.4 specifically) and you need to use print ( 'hello world!' ) in Python3.
Sorry if this isn't the answer to your main question; I admit that I wouldn't be able to help much there. But I could answer the last part.
Re: Parser errors
Posted: Tue Sep 23, 2014 2:58 pm
by stijn
I would first try it with the unmodified code from unix main(), and use a debugger to step through it and inspect values of variables as you go. EXC_BAD_ACCESS likely means pns or whatever it points to is not initialized properly possibly due to failed allocation or something like that.
Re: Parser errors
Posted: Wed Sep 24, 2014 12:45 am
by p-i-
So now I am using brackets for print, thanks!
I've switched from using the bare_arm do_str function to using the one in /unix/main.c
uint mp_verbose_flag = 1;
uint emit_opt = MP_EMIT_OPT_NONE;
bool compile_only = false;
// returns standard error codes: 0 for success, 1 for all other errors
STATIC int execute_from_lexer(mp_lexer_t *lex, mp_parse_input_kind_t input_kind, bool is_repl) {
    if (lex == NULL) {
        return 1;
    if (0) {
        // just tokenise
        while (!mp_lexer_is_kind(lex, MP_TOKEN_END)) {
            mp_token_show(mp_lexer_cur(lex));
            mp_lexer_to_next(lex);
        mp_lexer_free(lex);
        return 0;
    mp_parse_node_t pn = mp_parse(lex, input_kind, &parse_error_kind);
        // parse error
        mp_lexer_free(lex);
        return 1;
#if MICROPY_PY___FILE__
    if (input_kind == MP_PARSE_FILE_INPUT) {
        mp_store_global(MP_QSTR___file__, MP_OBJ_NEW_QSTR(source_name));
#endif
    mp_lexer_free(lex);
     printf("----------------\n"); // <-- I uncommented this
     mp_parse_node_print(pn, 0);
    mp_obj_t module_fun = mp_compile(pn, source_name, emit_opt, is_repl); // <-- fails here
    if (module_fun == mp_const_none) {
        // compile error
        return 1;
    if (compile_only) {
        return 0;
    // execute it
    nlr_buf_t nlr;
    if (nlr_push(&nlr) == 0) {
        mp_call_function_0(module_fun);
        nlr_pop();
        return 0;
    } else {
        // uncaught exception
        // check for SystemExit
        mp_obj_t exc = (mp_obj_t)nlr.ret_val;
        if (mp_obj_is_subclass_fast(mp_obj_get_type(exc), &mp_type_SystemExit)) {
            mp_obj_t exit_val = mp_obj_exception_get_value(exc);
            mp_int_t val;
            if (!mp_obj_get_int_maybe(exit_val, &val)) {
                val = 0;
            exit(val);
        mp_obj_print_exception((mp_obj_t)nlr.ret_val);
        return 1;
I uncommented the mp_parse_node_print lines
This produced compiler errors: searching under mp_parse_node_print, I find I need to set
#define MICROPY_DEBUG_PRINTERS      (1)
in mpconfigport.h, which then requires
Which I already included in the first listing.
Now when I run, I get the output:
[ 1] expr_stmt(32) (n=2)
[ 1] power(120) (n=3)
id(print)
[ 1] trailer_paren(136) (n=1)
[ 1] literal str(hello world!)
NULL
NULL
The line that fails in do_str is:
All of the parameters look reasonable.
YAY it works!
Hello world!
Strange thing is that I'm pretty sure I already tried the UNIX do_str and was getting the error. And now I'm not. Might have been a clean/build that shook something loose.
