what tools generate "qstr.i.last" file
fkeujjpdc
Post by fkeujjpdc » Mon Mar 27, 2017 2:08 am
How Generate qstr.i.last file , i found in makerules.mk
$(HEADER_BUILD)/qstr.i.last: $(SRC_QSTR) | $(HEADER_BUILD)/mpversion.h
$(ECHO) "GEN $@"
$(Q)if [ "$?" = "" ]; then \
echo "QSTR Looks like -B used, trying to emulate"; \
$(CPP) $(QSTR_GEN_EXTRA_CFLAGS) $(CFLAGS) $^ >$(HEADER_BUILD)/qstr.i.last; \
else \
$(CPP) $(QSTR_GEN_EXTRA_CFLAGS) $(CFLAGS) $? >$(HEADER_BUILD)/qstr.i.last; \
fi
but i can't find the CPP command,what is the CPP tools
Re: what tools generate "qstr.i.last" file
Post by dhylands » Mon Mar 27, 2017 3:33 am
CPP is the C pre-processor.
make provides a default definition of CPP which is defined to be $(CC) -E
You can see this if you do:
2145 >make -p | grep -w CPP
CPP = $(CC) -E
	$(Q)cat $(PY_QSTR_DEFS) $(QSTR_DEFS) $(QSTR_DEFS_COLLECTED) | $(SED) 's/^Q(.*)/"&"/' | $(CPP) $(CFLAGS) - | $(SED) 's/^"\(Q(.*)\)"/\1/' > $(HEADER_BUILD)/qstrdefs.preprocessed.h
CC is defined here: https://github.com/micropython/micropyt ... env.mk#L48
fkeujjpdc
Post by fkeujjpdc » Tue Mar 28, 2017 12:50 am
Thanks, :D
