Porting MicroPython to the STM32F429i
Pikachu
Post by Pikachu » Wed Oct 08, 2014 6:06 am
I tried to port MicroPython on the STM32F429i Board, but I have some problems with the Micro USB. :roll:
One difference between the STM32F4 Discovery and the STM32F429i is the pins which are used for the Micro USB connection.
The STM32F4 Discovery uses the pins PA9,PA11,PA12 and PA10, however the STM32F429i uses the PB15, PB14, PB13 and PB12 pins.
Now my question: How can I change the Micro USB pins in the MicroPython code?
Thanks for your help :D
Re: Porting MicroPython to the STM32F429i
Post by dhylands » Wed Oct 08, 2014 7:09 am
IIRC the openmv project uses a 429 (and runs micropythong so I suspect the work may be already done.
The stmhal/usbd_conf.c file does the pin configuration for USB.
Pikachu
Post by Pikachu » Wed Oct 08, 2014 7:46 am
Okay... So i have to say that Iam using the STM32F429i Discovery Board.
I already tried to change the usbd_conf.c, but i got no usb connection to the PC.
This Board has his own Programmer called ST-Link, with this its possible to get a .hex file on the board.
Therefor i think micropython is already running, but i cannot test it.
Is it possible to put code in the main.py file before porting it to the controller?
Post by dhylands » Wed Oct 08, 2014 2:59 pm
Pikachu wrote:Okay... So i have to say that Iam using the STM32F429i Discovery Board.
The contents of the initial boot.py and main.py can be found here:
https://github.com/micropython/micropyt ... #L139-L151
You can use the command:
pyb.repl_uart(pyb.UART(6,115200))
to get the REPL to show up on a UART (in addition to the USB).
