Need help, mp_lexer_new_from_str_len returning null
I'm trying to compile and run a script stored in flash. I'm not using a file system, the script is just stored as raw ascii. The problem I'm having is that mp_lexer_new_from_str_len() is returning NULL. Seems to be having trouble allocating memory for something.
There are many other things going on in my firmware and for me to narrow down whats causing it, I need to know what conditions would cause a lexer creation to fail so I know where to start looking in my firmware.
Thanks in advance.
Thanks in advance.
Re: Need help, mp_lexer_new_from_str_len returning null
It looks like mp_lexer_new_from_str_len should never return NULL. If it runs out of memory, it should raise a MemoryError exception.
I'm still having problems with this. I'm using the following code, which is used in the Minimal build as well as other builds.
Seems to be almost at random. The syntax of the script is correct and there is no way I could be having a memory problem, my heap is set to 16kb.
There are two def's. The first one call() is just a wrapper for a C function. The second one just calls the call function to do different things, sometimes it returns an int other times it returns a list.
But like I said, my error is coming from the lexer, when it does execute it runs fine. My mp engine is part of my firmware and running as a separate function.
mp_lexer_t *lex = mp_lexer_new_from_str_len(MP_QSTR__lt_stdin_gt_, src, strlen(src), 0);
import c_sample
def call(arg0,arg1,arg2,arg3,arg4):
return c_sample.call_callback(arg0, arg1, [arg2,arg3,arg4])
def test():
t=call(0x23,0x04,0x16,0x00,0x00)
if len(t) < 1
return
t[10]=0x06
t[14]=0x63
call(0x20,t,0,0,0)
return
test()
Is src a null-terminated string? strlen requires it.
Yes, for testing I'm passing it a constant string like this:dhylands wrote:Is src a null-terminated string? strlen requires it.
"def test():\n t=call(0x23,0x04,0x16,0x00,0x00)\n if len(t) < 1\n return\n t[10]=0x06\n t[14]=0x63\n call(0x20,t,0,0,0)\n return\ntest()"
The call() function never gives an error, that one is compiled as right after mp is initialized. The test() function is compiled and executed whenever an event happens in my firmware (no interrupts are used for the event). Sometimes the script runs without problems a handful of times, but then starts giving a lexer error.
What error?
Did you setup your heap?
Are you running out of memory?
- No error codes per se, just returns NULL.
- My heap is currently set at 16kb:
static char heap[16384]
I can't imagine that with a heap that large and a script that small that I would be running out of memory.
dhylands wrote:What error?
You'll probably need to sprinkle some prints through the code then, because I don't see anyway that mp_lexer_new_from_str_len returns NULL except via a failure to allocate from the heap.
Actually, I forgot to mention that the heap is NOT declared in main(). Neither is the stack. My init function, heap, stack and gc callbacks are all in a separate file. Would this cause any issues?
static volatile char *stack_top;
static char heap[16384] = {0xff};
void mp_initialize(void)
mp_stack_set_top(stack_top);
gc_init(heap, heap + sizeof(heap));
mp_init();
I wouldn't expect that to cause any problems related to what you're seeing, provided your initialize function is being called.
