how to decompile bytecode into human readable format
Re: how to decompile bytecode into human readable format
Are you using pybricks? If so, the source code appears to be here: https://github.com/pybricks/pybricks-micropython
Can you provide these compiled mpy to me? jon <at> cunninglogic <dot> com, or explain to me what a lego spike hub is and where I can buy one?MasterOfGizmo wrote: ↑Sun Nov 29, 2020 8:44 pmAny news on this?
The Lego Spike hub runs micropython and the source code doesn't seem to be public. Its default UI comes in form of a mpy and can easily be downloaded from the device. It would be nice to be able to decompile and modify this.
I've got a semi working disassembler done. Hoping to make it stable, then work on a decompiler.
Check this repo.. this is regularly updated and there is some work going on here related to decompiler.
https://github.com/gpdaniels/spike-prime
The following folder contains the file sytem files (mpy) from various versions of the Lego Spike and Lego Mindstorms inventor firmwares..
https://github.com/gpdaniels/spike-prim ... filesystem
The current version of decompiler is here..
https://github.com/gpdaniels/spike-prim ... decompiler
Some conversations on it is here:
https://github.com/gpdaniels/spike-prime/pull/10
Thanks, my decompiler is somewhat reliable now, but im off on another project for the time being, work has me slammedmohankrr wrote: ↑Mon Dec 28, 2020 11:26 pmCheck this repo.. this is regularly updated and there is some work going on here related to decompiler.
Can I compile a py file using mpy-cross and run it directly using micropython (without any import or etc.)?
thanks
thanks
Can you clarify what you mean? You'd like to copy the .mpy file to the device and have it run automatically on startup?
Or you want to run the .mpy directly from RAM (e.g. using pyboard.py).
