[SOLVED]frozen to REPL - not showing intro text
jickster
Post by jickster » Tue Oct 31, 2017 7:06 pm
I'm using the teensy port.
When I have teensy\memzip_files\main.py set to the following, the REPL introductory text appears
print("Executing main.py")
led = pyb.LED(1)
led.on()
pyb.delay(100)
led.off()
pyb.delay(100)
led.on()
pyb.delay(100)
MicroPython v1.9.2 on 2017-10-31; Teensy-3.1 with MK20DX256
But when I remove
pyb.delay(100)
from the end, although I can still enter text in the REPL prompt, I do not see the introductory prompt.
I'm using PuTTY for the serial port terminal.
Re: frozen to REPL - not showing intro text
Post by dhylands » Tue Oct 31, 2017 8:41 pm
I suspect what's happening is that the introductory text is being printed before the USB-serial link gets setup and therefore gets dropped.
Adding the delay allows the host/teensy to get it setup.
I see the same thing quite often on the pyboard as well.
If I'm at the REPL, I can press Control-D (soft reset) and then you should see the introductory text since in this case the USB-serial link doesn't get torn down and initialized.
