Unix Build Fails
SwimDude0614
Unix Build Fails
Post by SwimDude0614 » Mon Mar 10, 2014 2:50 am
I have a fresh repository with no changes. When I try to build the unix version, I get:
david@balrogJr-Saucy:~/reusable/micropython/unix$ make clean
rm -f micropython
rm -rf build
david@balrogJr-Saucy:~/reusable/micropython/unix$ make V=1
mkdir -p build/py
makeqstrdata ../py/qstrdefs.h qstrdefsport.h
python ../py/makeqstrdata.py ../py/qstrdefs.h qstrdefsport.h > build/py/qstrdefs.generated.h
  File "../py/makeqstrdata.py", line 41
    print('({}:{}) bad qstr format, got {}'.format(infile, line_number, line), file=sys.stderr)
SyntaxError: invalid syntax
make: *** [build/py/qstrdefs.generated.h] Error 1
I'm running Ubuntu 13.10 64-bit with gcc 4.8.1 and python 2.7.5 and 3.3.2.
SwimDude0614
Re: Unix Build Fails
Post by SwimDude0614 » Mon Mar 10, 2014 2:46 pm
I logged into my webserver this morning to try the build again. It is running Ubuntu 12.04.4 64-bit, gcc 4.6.3-1ubuntu5, python 2.7.3
When I do a "find", it appears that there really isn't any file called "readline.h".
CC main.c
main.c:23:31: fatal error: readline/readline.h: No such file or directory
compilation terminated.
make: *** [build/main.o] Error 1
dzweb@zemon1204:~/micropython/unix$ find .. -name readline.h
I'm getting the impression that there's something weird about my environment on my home desktop, so the errors in this post are probably worth focusing on more than my first post.
Post by dhylands » Mon Mar 10, 2014 2:53 pm
I just posted a pull request for the problem in your first post a few hours ago:
https://github.com/micropython/micropython/pull/335
To fix the second problem, I think that if you do:
sudo apt-get install libreadline-dev
then you should get further.
SwimDude0614
Post by SwimDude0614 » Mon Mar 10, 2014 5:48 pm
Great! Working on my remote server now. I'll update tonight regarding my first post.
Update
That worked! Thanks for the push.
