Zacwire - Tsic506
Chris001
Zacwire - Tsic506
Post by Chris001 » Sun Feb 25, 2018 7:36 pm
I would connect the Temperature sensor Tsic506 on my ESP32 board.
Does someone has already ported the zacwire protocol or successfull connect a Tsicxxx Sensor via pure Micropython?
Chris
Chris001
Re: Zacwire - Tsic506
Post by Chris001 » Wed Mar 07, 2018 7:22 pm
Im wondering why the first code does'nt return a correct result but the second does
The code is runnung on an ESP32.
Any ideas?
more about zagwire
https://www.mikrocontroller.net/attachm ... Oct-06.pdf
MINTEMP = -10
MAXTEMP = 60
temperatur = []
tempvalue = []
def get_temperatur():
    if temperatur:
        tempstring = int("".join(str(val) for val in temperatur), 2)
        return round(float(tempstring / 2047 * (MAXTEMP - MINTEMP)) - MINTEMP, 1)
def callback(p):
    value = p.value()
    tempvalue.append(value)
    if len(tempvalue) == 6 and tempvalue != valid:
        tempvalue.pop(0)
    if len(tempvalue) == 20:
        temperatur.clear()
        temperatur.extend(tempvalue[1:9] + tempvalue[11:19])
        tempvalue.clear()
pin = machine.Pin(26, machine.Pin.IN, machine.Pin.PULL_UP)
pin.irq(trigger=machine.Pin.IRQ_FALLING, handler=callback)
MINTEMP = -10
MAXTEMP = 60
class Temperatur(object):
    _valid = [1, 0, 0, 0, 0, 0]
    def __init__(self, pin, celsius=True):
        self._pin = machine.Pin(pin, machine.Pin.IN, machine.Pin.PULL_UP)
        self._celsius = celsius
        self._tempvalue = []
        self._temperatur = []
    def _callback(self, p):
        value = p.value()
        if not len(self._tempvalue) and not value:
            return
        self._verify(value)
    def _verify(self, value):
        tempvalue = self._tempvalue
        tmp_len = len(tempvalue)
        if tmp_len == 6 and tempvalue != self._valid:
            tempvalue.pop(0)
        if tmp_len == 20:
            self._temperatur.clear()
            self._temperatur.extend(tempvalue[1:9] + tempvalue[11:19])
            tempvalue.clear()
    def sensor_on(self):
        self._pin.irq(trigger=machine.Pin.IRQ_FALLING, handler=self._callback)
    def sensor_off(self):
        pass
    def get_temperatur(self):
        if self._temperatur:
            print(self._temperatur)
            tempstring = int("".join(str(val) for val in self._temperatur), 2)
temp = Temperatur(26)
temp.sensor_on()
print(temp.get_temperatur())
content of self._tempvalue
[1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 1, 0, 1, 1, 1, 1, 1...
but is must be a sequence of..
content of tempvalue
[1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 1, 0,
1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 1, 1,
1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 1,
1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 1, 0, 1, 0, 1, 1,
1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0..
thank you
chris
