[SOLVED]why is there no mp_obj type for small int?
jickster
Post by jickster » Sun Apr 08, 2018 8:03 pm
Re: why is there no mp_obj type for small int?
Post by deshipu » Mon Apr 09, 2018 6:50 am
Because small ints are stuffed directly into the pointers themselves.
Post by dhylands » Mon Apr 09, 2018 4:40 pm
And in particular, this is where it's documented:
https://github.com/micropython/micropyt ... .h#L51-L93
The pyboard uses MICROPY_OBJ_REPR_A
jickster
Post by jickster » Mon Apr 16, 2018 8:28 pm
Then why is there a `qstr` typedef?
Now I know the typedef `qstr` is not an MP_OBJ - you have to use MP_OBJ_NEW_QSTR() to shift the bits to turn it into an MP_OBJ - but the fact remains that the typedef `qstr` exists.
I like that `qstr` exists - for reasons of type safety - so then wouldn't it similarly make sense to also have a `small_int` type?
Post by dhylands » Mon Apr 16, 2018 8:35 pm
Having a qstr typedef serves mostly as documentation.
A qstr is really just an integer, and if you saw a function:
void some_function(qstr name);
then you know that the name argument is a qstr, whereas
void some_function(size_t name);
wouldn't tell you that same thing.
And a qstr isn't an mp_obj type. It has to be converted to an mp_obj type using the appropriate macro.
jickster
Post by jickster » Tue Apr 17, 2018 4:06 am
dhylands wrote:Having a qstr typedef serves mostly as documentation.
And the same argument could be made about small int.
So why isn’t there a typedef for small int?
Sent from my iPhone using Tapatalk
stijn
Post by stijn » Tue Apr 17, 2018 8:31 am
Isn't that mp_int_t ?
Post by dhylands » Tue Apr 17, 2018 4:02 pm
I'm not aware of any (or many) functions which would take just a small int as an argument, except for the macros which convert to/from the mp_obj_t and the small int.
jickster
Post by jickster » Tue Apr 17, 2018 4:08 pm
A small int is 29-bits. mp_int_t is 32
stijn
Post by stijn » Tue Apr 17, 2018 6:05 pm
Well, yes, but like Dave says: just like functions wanting a qstr take a qstr and not a pointer-sized type, functions wanting an int use mp_int_t. Or maybe I'm missing the point.
