Documentation generation from C comments
BramPeeters
Post by BramPeeters » Wed Apr 11, 2018 9:46 am
I was wondering how the documentation is generated for C 'drivers', eg pin.c
The end result i can see eg at https://docs.micropython.org/en/latest/ ... b.Pin.html, and apparently a document generation tool sphinx is used.
Now i see 'formatted' comments partially matching this in eg \ports\stm32\pin.c
Eg:
/// \method value([value])
/// Get or set the digital logic level of the pin:
/// - With no argument, return 0 or 1 depending on the logic level of the pin.
/// - With `value` given, set the logic level of the pin. `value` can be
/// anything that converts to a boolean. If it converts to `True`, the pin
/// is set high, otherwise it is set low.
But some text is not present in the C file at all such as the entire 'Pin.init(mode, pull=Pin.PULL_NONE, af=-1) ' descirption, which just has
// init(mode, pull=None, af=-1, *, value, alt)
in the code.
The only place where the full description is present seems to be docs/library/pyb.Pin.rst. So this seems to be the input file for sphinx ?
So is this file maintained separately from the c code ?
Or is it generated from the c code (with which tool and where does the text that is not present in C comes from then ?)
Regards
Bram
Re: Documentation generation from C comments
Post by pythoncoder » Thu Apr 12, 2018 6:42 am
I suspect this is something from the past which was tried and abandoned. In practice documentation is maintained by raising pull requests against the .rst files.
BramPeeters
Post by BramPeeters » Sat Apr 14, 2018 12:10 am
Too bad :(
Thanks for the clarification !
Post by pythoncoder » Sat Apr 14, 2018 11:18 am
I think there are good reasons for this. MicroPython has grown to support multiple platforms and the docs vary between these, so I suspect auto-generation would no longer work properly.
