STATIC mp_obj_t type_call(mp_obj_t self_in, size_t n_args, size_t n_kw, const mp_obj_t *args) {
// instantiate an instance of a class
mp_obj_type_t *self = MP_OBJ_TO_PTR(self_in);
if (self->make_new == NULL) {
if (MICROPY_ERROR_REPORTING == MICROPY_ERROR_REPORTING_TERSE) {
mp_raise_TypeError("cannot create instance");
} else {
nlr_raise(mp_obj_new_exception_msg_varg(&mp_type_TypeError,
"cannot create '%q' instances", self->name));
// make new instance
mp_obj_t o = self->make_new(self, n_args, n_kw, args);
// return new instance
return o;
All examples I can find don't use that arg like "list_make_new"
STATIC mp_obj_t list_make_new(const mp_obj_type_t *type_in, size_t n_args, size_t n_kw, const mp_obj_t *args) {
(void)type_in;
mp_arg_check_num(n_args, n_kw, 0, 1, false);
switch (n_args) {
case 0:
// return a new, empty list
return mp_obj_new_list(0, NULL);
case 1:
default: {
// make list from iterable
// TODO: optimize list/tuple
mp_obj_t list = mp_obj_new_list(0, NULL);
return list_extend_from_iter(list, args[0]);
