[SOLVED]Porting core micropython: architecture-specific functions
jickster
Post by jickster » Mon May 21, 2018 6:44 pm
This isn't about all the peripherals, just the portions of the code to run core micropython.
What functions are unique to a given architecture (x86, ARM, TI-DSP)?
1. nlr-related assembly code
2. mp_uint_t gc_helper_get_regs_and_sp(mp_uint_t *regs)
Anything else?
Re: Porting core micropython: architecture-specific functions
Post by dhylands » Mon May 21, 2018 6:56 pm
I think that the nlr code (which I'm pretty sure can be done using setjmp/longjmp), the gchelper function, and the startup/ISR code are the primary non-peripheral things.
Supporting the native and viper code generators also requires architecture specific code, but this functionality isn't required to get MicroPython up and running.
