How to get a ll out of an objint (inverse of mp_obj_new_int_from_ll)
Posted: Thu Sep 27, 2018 5:04 pm
by BramPeeters
After creating an objint with mp_obj_new_int_from_ll, is there a way to get the long long out of there afterwards?
At the moment I am only seeing the mp_int_t mp_obj_get_int(mp_const_obj_t arg) function, but that returns an mp_int_t which is not suppose to have the long long size.
Is mp_obj_int_to_bytes_impl intended for that, with a pointer to a 'long long' as buffer argument ?
Or will this be some internal representation since i am using MICROPY_LONGINT_IMPL_MPZ (not really familiar with how this stores large numbers)
Bram
Re: How to get a ll out of an objint (inverse of mp_obj_new_int_from_ll)
Posted: Thu Sep 27, 2018 6:33 pm
by stijn
Don't have time to check all my code but this should get you started; as far as I know it depends on sizeof(long long) and on whether you're building as 32bit or 64bit. For instance in a 64bit build where sizeof(long long) is the same as sizeof(mp_int_t) you can just use mp_obj_get_int. But for a 32bit build where sizeof(long long) is 8, I apparently also found no built-in way and ended up with this at one point (note this works for signed as well, just needs casting):
    //mpz -> 64bit integer for 32bit builds
    inline std::uint64_t mpz_to_64bit_int( const mp_obj_int_t* arg, bool is_signed )
      static_assert( MPZ_DIG_SIZE == 16, "Expected MPZ_DIG_SIZE == 16" );
      //see mpz_as_int_checked
      const std::uint64_t maxCalcThreshold = is_signed ? 140737488355327 : 281474976710655;
      auto i = &arg->mpz;
      if( !is_signed && i->neg )
        RaiseTypeException( "Source integer must be unsigned" );
      auto d = i->dig + i->len;
      std::uint64_t val = 0;
      while( d-- > i->dig )
        if( val > maxCalcThreshold )
          RaiseOverflowException( "Value too large for 64bit integer" );
        val = ( val << MPZ_DIG_SIZE ) | *d;
#ifdef _MSC_VER
  #pragma warning( disable : 4146 )
#endif
      if( i->neg )
        val = -val;
#ifdef _MSC_VER
  #pragma warning( default : 4146 )
#endif
      return val;
Posted: Thu Sep 27, 2018 7:21 pm
by BramPeeters
My int's are 32 bit and long long's 64 bit, so thank you very much !
