float() different result returned for ppc64 vs x86_64
My understanding is that all hardware/software should implement https://en.wikipedia.org/wiki/IEEE_754 and return the same results. However when issuing float operations I see differences in results that cause the float_parse.py test to fail between ppc64 and x86_64:
PPC64 result:
~/aports/testing/micropython/src/micropython-1.9.4/tests $ ../ports/unix/micropython
MicroPython v3.8.0-1909-g685fa426c5-dirty on 2018-09-11; linux version
>>> float('.' + '9' * 70)
1.000000000000001
X86_64
Linux 1060f6cfbd6b
1.0
PPC64 result:
1.000000000000001
X86_64
Linux 1060f6cfbd6b
1.0
Re: float() different result returned for ppc64 vs x86_64
I KNOW this issue has been posted AND addressed on the forum somewhere.
There were a couple of issues posted in thread viewtopic.php?f=3&t=5247 but the inconsistency between the ppc64 and x86_64 result wasn't addressed so was split out here. Do you know of another thread? I searched but couldn't find a specific resolution? Thanks
That’s the one I was thinking of. I see your point why it’s not the same kind of difference.
There may be two separate issues here:
the binary value that float() outputs AND
the value print() outputs.
Put a breakpoint in C code of both cases and compare the binary value of the float object that’s in memory and reply back.
I ran across https://bugs.mysql.com/bug.php?id=82760 that describes how floating point calculations can be a bit different on some cpu types when using the "-Os" compiler optimization settings. Because -Os enables the -fexpensive-optimizations option which causes ppc64 to compute floating point operations slightly differently. It is suggested from the above link that one of these enabled "expensive-optimizations" is to make use of the Fuse Multiply-Add instructions on ppc64 that are responsible for the slight differences in calculation. One suggested way to correct this is to use the -ffp-contract=off to disable the use of the Fused Multiply-Aadd instructions. I tried the following patch successfully to fix the issue on ppc64:
--- a/ports/unix/Makefile
+++ b/ports/unix/Makefile
@@ -30,7 +30,7 @@
CFLAGS += -g
COPT = -O0
else
-COPT = -Os -fdata-sections -ffunction-sections -DNDEBUG
+COPT = -Os -ffp-contract=off -fdata-sections -ffunction-sections -DNDEBUG
# _FORTIFY_SOURCE is a feature in gcc/glibc which is intended to provide extra
# security for detecting buffer overflows. Some distros (Ubuntu at the very least)
# have it enabled by default.
@@ -30,7 +30,7 @@
CFLAGS += -g
COPT = -O0
else
As suggested, to see the values returned from a "float('.' + '9' * 70)" operation a breakpoint was added at float_print().
When hit the value of self->value ( and o_val) shows that when building micropython with default cflags x86_64 computes a float value of 1, while ppc64 computes a float value of 1.0000000000000009
x86_64:
Breakpoint 1, float_print (print=0x5555555c2860 <mp_sys_stdout_print>, o_in=0x7ffff7d62e40, kind=PRINT_REPR) at ../../py/objfloat.c:109
109 STATIC void float_print(const mp_print_t *print, mp_obj_t o_in, mp_print_kind_t kind) {
(gdb) step
111 mp_float_t o_val = mp_obj_float_get(o_in);
(gdb) step
mp_obj_float_get (self_in=0x7ffff7d62e40) at ../../py/obj.h:106
106 { return ((((mp_int_t)(o)) & 3) == 0); }
(gdb) step
208 return self->value;
(gdb) print self->value
$1 = 1
(gdb) step
float_print (print=0x5555555c2860 <mp_sys_stdout_print>, o_in=<optimized out>, kind=<optimized out>) at ../../py/objfloat.c:123
123 mp_format_float(o_val, buf, sizeof(buf), 'g', precision, '\0');
(gdb) print o_val
$2 = 1
(gdb) cont
Continuing.
1.0
>>> quit
ppc64 without -ffp-contract=off
Breakpoint 1, 0x00000001000313ac in float_print (print=0x10008d940 <mp_sys_stdout_print>, o_in=0x7ffff7cd7360, kind=PRINT_REPR) at ../../py/objfloat.c:109
(gdb) list
104
105 return val;
106 }
107 #endif
108
110 (void)kind;
112 #if MICROPY_FLOAT_IMPL == MICROPY_FLOAT_IMPL_FLOAT
113 char buf[16];
(gdb) next
(gdb) step
mp_obj_float_get (self_in=0x7ffff7cd7360) at ../../py/obj.h:106
(gdb) step
(gdb) step
float_print (print=0x10008d940 <mp_sys_stdout_print>, o_in=<optimized out>, kind=<optimized out>) at ../../py/objfloat.c:123
(gdb) print o_val
$10 = 1.0000000000000009
(gdb) cont
Continuing.
1.000000000000001
[Inferior 1 (process 144200) exited normally]
(gdb)
When adding the -ffp-contract=off to cflags and rebuilding micropython ppc64 now returns a self->value (1) for the float operation consistent with x86_64.
ppc64 with -ffp-contract=off
Breakpoint 1, 0x00000001000313d0 in float_print (print=0x10008d940 <mp_sys_stdout_print>, o_in=0x7ffff7cd6e20, kind=PRINT_REPR) at ../../py/objfloat.c:109
(gdb) list
104
105 return val;
106 }
107 #endif
108
110 (void)kind;
113 char buf[16];
(gdb) step
(gdb) step
mp_obj_float_get (self_in=0x7ffff7cd6e20) at ../../py/obj.h:106
(gdb) step
(gdb) step
(gdb) print o_val
$1 = 1
(gdb) continue
Continuing.
1.0
Note: As a check, rebuilding the x86_64 micropython binary with the fp-contract=off does not change the value returned for the float operation.
x86_64:
(gdb) step
(gdb) step
(gdb) step
$1 = 1
(gdb) step
(gdb) print o_val
$2 = 1
(gdb) cont
Continuing.
1.0
>>> quit
(gdb) list
104
105 return val;
106 }
107 #endif
108
110 (void)kind;
113 char buf[16];
(gdb) next
(gdb) step
(gdb) step
(gdb) step
(gdb) print o_val
(gdb) cont
Continuing.
1.000000000000001
(gdb)
(gdb) list
104
105 return val;
106 }
107 #endif
108
110 (void)kind;
113 char buf[16];
(gdb) step
(gdb) step
(gdb) step
(gdb) step
(gdb) print o_val
$1 = 1
(gdb) continue
Continuing.
1.0
So problem solved?
If consistency across architectures to meet https://en.wikipedia.org/wiki/IEEE_754 is the objective then it would seem to be necessary to build with the -ffp-contract=off. I think this change would fix the problem as long as there are no objections?
You should create an issue on github and link to this post to demonstrate the discrepancy.mksully22 wrote:If consistency across architectures to meet https://en.wikipedia.org/wiki/IEEE_754 is the objective then it would seem to be necessary to build with the -ffp-contract=off. I think this change would fix the problem as long as there are no objections?
Also create the pull request yourself since this involves only a compile options change and should be simple and quick for admins to accept or reject.
I will do that. Thanks!
