mp_obj_new_int causing uncaught exception when value passed is greater than 30 bits
cduran
Post by cduran » Wed Oct 31, 2018 5:20 pm
Like the subject line says.
I'm using mp_obj_new_int to pass values between C and python. When I try to pass a number that is greater than 30 bits long I get an "uncaught exception".
Should I be using a different function for larger integers?
jickster
Re: mp_obj_new_int causing uncaught exception when value passed is greater than 30 bits
Post by jickster » Wed Oct 31, 2018 5:38 pm
Paste the actual code for mp_obj_new_int that you’re using. If it can’t fit in a small int, it calls
mp_obj_t mp_obj_new_int_from_ll.
And when are you getting the exception?
Are you in an interrupt?
cduran
Post by cduran » Thu Nov 01, 2018 4:26 pm
Fixed my problem.
Setting MICROPY_LONGINT_IMPL to MICROPY_LONGINT_IMPL_LONGLONG did the trick.
