It is generated when a build is compiled.
This is useful to see how much memory space a build uses and especially useful to see how much space is left over for a specific board implementation. (Perhaps not so useful for Unix.)
I am writing a parser and viewer to visualize these memory issues.
I have several ".map" files but I would like more from diff people and boards to see the variations and make my parser more robust.
Please zip up your ".map" files and send them to me if you want to help me make this work.
Here is my initial sample output for a single sample of a Teensy, stmhal, and unix build (64bit).
Graphing coming soon. Also ability to see all functions in map.
FYI:
.text is where program instructions are stored (FLASH)
.data is where initialised static variables are stored (SRAM)
.bss is where uninitialised data is stored
For: teensy_micropython_dh_01.map
Found 6 sections. 7801 lines read
['Memory Configuration', 'Discarded input sections', 'Linker script and memory map', 'Allocating common symbols', 'OUTPUT', 'Preamble']
Reading:
Parsing:
Parsing Blocks
Parsing Common Symbols
Parsing Linker and Mem map
Memory stats
.text start=0x00000000 length=0x2e824 (0k,186kB)
.glue_7 start=0x0002e824 length=0x0 (186k,0B)
.glue_7t start=0x0002e824 length=0x0 (186k,0B)
.vfp11_veneer start=0x0002e824 length=0x0 (186k,0B)
.v4_bx start=0x0002e824 length=0x0 (186k,0B)
.iplt start=0x0002e824 length=0x0 (186k,0B)
.rel start=0x0002e824 length=0x0 (186k,0B)
.ARM start=0x0002e824 length=0x0 (186k,0B)
.usbdescriptortable start=0x1fff8000 length=0xa0 (524256k,160B)
.dmabuffers start=0x1fff80a0 length=0x0 (524256k,0B)
.usbbuffers start=0x1fff80a0 length=0x360 (524256k,864B)
.data start=0x1fff8400 length=0x4dc (524257k,1kB)
.igot start=0x1fff88dc length=0x0 (524258k,0B)
.noinit start=None length=None (0k,0)
.bss start=0x1fff88dc length=0x38c (524258k,908B)
.heap start=0x1fff8c68 length=0x4000 (524259k,16kB)
.stack start=0x1fffcc68 length=0x800 (524275k,2kB)
For: unix_micropython_dh_01.map
Found 7 sections. 8393 lines read
['Memory Configuration', 'Discarded input sections', 'Cross Reference Table', 'Linker script and memory map', 'Allocating common symbols', 'OUTPUT', 'Preamble']
Reading:
Parsing:
Parsing Blocks
Parsing Cross refs
Memory stats
.interp start=0x0000000000400238 length=0x1c (4096k,28B)
.note start=0x0000000000400254 length=0x20 (4096k,32B)
.note start=0x0000000000400274 length=0x24 (4096k,36B)
.hash start=None length=None (0k,0)
.gnu start=0x0000000000400298 length=0xac (4096k,172B)
.dynsym start=0x0000000000400348 length=0xc48 (4096k,3kB)
.dynstr start=0x0000000000400f90 length=0x502 (4099k,1kB)
.gnu start=0x0000000000401492 length=0x106 (4101k,262B)
.gnu start=0x0000000000401598 length=0x0 (4101k,0B)
.gnu start=0x0000000000401598 length=0xa0 (4101k,160B)
.rela start=0x0000000000401638 length=0x150 (4101k,336B)
.rela start=0x0000000000401788 length=0xa38 (4101k,2kB)
.init start=0x00000000004021c0 length=0x1a (4104k,26B)
.plt start=0x00000000004021e0 length=0x6e0 (4104k,1kB)
.text start=0x00000000004028c0 length=0x297a0 (4106k,165kB)
.fini start=0x000000000042c060 length=0x9 (4272k,9B)
.rodata start=0x000000000042c080 length=0x13850 (4272k,78kB)
.rodata1 start=None length=None (0k,0)
.eh_frame_hdr start=0x000000000043f8d0 length=0x271c (4350k,9kB)
.eh_frame start=0x0000000000441ff0 length=0xc1bc (4359k,48kB)
.gcc_except_table start=None length=None (0k,0)
.exception_ranges start=0x000000000044e1ac length= (4408k,)
.eh_frame start=None length=None (0k,0)
.exception_ranges start=None length=None (0k,0)
.tdata start=None length=None (0k,0)
.tbss start=None length=None (0k,0)
.preinit_array start=0x000000000064edcc length=0x0 (6459k,0B)
.init_array start=0x000000000064edd0 length=0x8 (6459k,8B)
.fini_array start=0x000000000064edd8 length=0x8 (6459k,8B)
.ctors start=None length=None (0k,0)
.dtors start=None length=None (0k,0)
.jcr start=0x000000000064ede0 length=0x8 (6459k,8B)
.data start=None length=None (0k,0)
.dynamic start=0x000000000064ede8 length=0x210 (6459k,528B)
.got start=0x000000000064eff8 length=0x8 (6459k,8B)
.got start=0x000000000064f000 length=0x380 (6460k,896B)
.data start=0x000000000064f380 length=0x18 (6460k,24B)
.tm_clone_table start=0x000000000064f398 length=0x0 (6460k,0B)
.data1 start=0x000000000064f398 length= (6460k,)
.bss start=0x000000000064f3a0 length=0x600 (6460k,1kB)
.lbss start=0x000000000064f9a0 length= (6462k,)
.lrodata start=None length=None (0k,0)
.ldata start=0x0000000000a4f9a0 length=0x0 (10558k,0B)
.stab start=None length=None (0k,0)
.stabstr start=None length=None (0k,0)
.comment start=0x0000000000000000 length=0x24 (0k,36B)
.debug start=None length=None (0k,0)
.line start=None length=None (0k,0)
.debug_srcinfo start=None length=None (0k,0)
.debug_sfnames start=None length=None (0k,0)
.debug_aranges start=None length=None (0k,0)
.debug_pubnames start=None length=None (0k,0)
.debug_info start=None length=None (0k,0)
.debug_abbrev start=None length=None (0k,0)
.debug_line start=None length=None (0k,0)
.debug_frame start=None length=None (0k,0)
.debug_str start=None length=None (0k,0)
.debug_loc start=None length=None (0k,0)
.debug_macinfo start=None length=None (0k,0)
.debug_weaknames start=None length=None (0k,0)
.debug_funcnames start=None length=None (0k,0)
.debug_typenames start=None length=None (0k,0)
.debug_varnames start=None length=None (0k,0)
.debug_pubtypes start=None length=None (0k,0)
.debug_ranges start=None length=None (0k,0)
.debug_macro start=None length=None (0k,0)
.gnu start=None length=None (0k,0)
/DISCARD/ start=None length=None (0k,0)
For: stmhal_firmware_dh_01.map
Found 7 sections. 15591 lines read
Reading:
Parsing:
Parsing Blocks
Parsing Cross refs
Memory stats
.isr_vector start=0x08000000 length=0x3520 (131072k,13kB)
.text start=0x08020000 length=0x3d418 (131200k,245kB)
.glue_7 start=0x0805d418 length=0x0 (131445k,0B)
.glue_7t start=0x0805d418 length=0x0 (131445k,0B)
.vfp11_veneer start=0x0805d418 length=0x0 (131445k,0B)
.v4_bx start=0x0805d418 length=0x0 (131445k,0B)
.iplt start=0x0805d418 length=0x0 (131445k,0B)
.rel start=0x0805d418 length=0x0 (131445k,0B)
.data start=0x20000000 length=0x60 (524288k,96B)
.igot start=0x20000060 length=0x0 (524288k,0B)
.bss start=0x20000060 length=0x278c (524288k,9kB)
.heap start=0x200027ec length=0x4000 (524297k,16kB)
.stack start=0x200067ec length=0x800 (524313k,2kB)
.ARM start=0x00000000 length=0x37 (0k,55B)
