A couple of questions re maths
Firstly, is it feasible to provide access to the four arithmetic operations in the FPU in assembler? I've been unable to locate any documentation about how the FPU is accessed in code. If this could be achieved it would presumably provide a means for interrupt handlers to process floats.
Secondly, the file stmhal/arm_math.h suggests that there is support for a range of useful maths functions including IIR and FIR filtering, PID controllers, matrix and vector operations - many of application in embedded projects. Is there any scope for accessing at least a subset of these from a MicroPython library, or would it bust the vital "Micro" attribute to do so?
Re: A couple of questions re maths
When I'm not sure how to code something in assembler, I normally let the compiler do it for me. For example, this C file: when compiled using these flags: will produce this assembler:
float foo(float a, float b) {
return a + b;
arm-none-eabi-gcc -c -mthumb -mtune=cortex-m4 -mabi=aapcs-linux -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -gstabs -Wa,-ahldms=float.cod float.c
1:float.c **** float foo(float a, float b) {
78 .LM0:
79 .LFBB1:
80 @ args = 0, pretend = 0, frame = 8
81 @ frame_needed = 1, uses_anonymous_args = 0
82 @ link register save eliminated.
83 0000 80B4 push {r7}
84 0002 83B0 sub sp, sp, #12
85 0004 00AF add r7, sp, #0
86 0006 87ED010A fsts s0, [r7, #4]
87 000a C7ED000A fsts s1, [r7]
2:float.c **** return a + b;
89 .LM1:
90 000e 97ED017A flds s14, [r7, #4]
91 0012 D7ED007A flds s15, [r7]
92 0016 77EE277A fadds s15, s14, s15
3:float.c **** }
94 .LM2:
95 001a B0EE670A fcpys s0, s15
96 001e 0C37 adds r7, r7, #12
97 0020 BD46 mov sp, r7
98 @ sp needed
99 0022 5DF8047B ldr r7, [sp], #4
100 0026 7047 bx lr
I think there're more than 4 instructions needed, because you also need mov/load/store instructions. Implementing all this in the inline assembler is entirely feasible, but not on my agenda. Feel free to submit a patch for it though!pythoncoder wrote:Firstly, is it feasible to provide access to the four arithmetic operations in the FPU in assembler?
Sounds like a perfect job for "loadable native modules" https://github.com/micropython/micropython/issues/583Secondly, the file stmhal/arm_math.h suggests that there is support for a range of useful maths functions including IIR and FIR filtering, PID controllers, matrix and vector operations - many of application in embedded projects. Is there any scope for accessing at least a subset of these from a MicroPython library, or would it bust the vital "Micro" attribute to do so?
@dhylands That's a nice approach. Looking at the assembler code it does look as if a bit of magic is involved in getting the float arguments into the routine: as far as I can see they are already in S0 and S1 rather than being on the stack. To satisfy my curiosity I'll try your technique to investigate how that occurs but I fear that applying the knowledge or submitting patches is beyond my competence. My C is rusty and to date I've failed to follow the MicroPython assembler source beyond a certain point.
@Damien
I appreciate that there are higher priorities than further enhancing the assembler and the current subset is very capable. Discovering all that C maths code did pique my curiosity, though
@Damien
To date I haven't got past first base with the FPU. Perhaps someone could point out where I'm going wrong. I started out with this integer code (which works) with the intention of adapting it for floats
I then compiled the following code using the flags as @dhylands suggested
this yielded the following assembler (edited to show only the interesting bit)
It seemed clear what was going on here so I used the resultant opcodes to modify my integer code for FP. Unfortunately the outcome is a crash.
The code crashes on execution of any of the floating point instructions. I fear I'm doing something very silly indeed but I can't see it
import array
a = array.array("i", [3, 4, 0])
@micropython.asm_thumb
def mult(r0):
mov(r3, r0) # r3 = address of array[0]
ldr(r0, [r3, 0])
add(r3, 4) # address of array[1]
ldr(r1, [r3, 0])
add(r3, 4) # address of array[2]
mul(r0, r1)
str(r0, [r3, 0])
mult(a)
print(a)
void foo(float *a, float *b, float *result) {
*result = *a * *b ;
84 0000 80B4 push {r7}
85 0002 85B0 sub sp, sp, #20
86 0004 00AF add r7, sp, #0
87 0006 F860 str r0, [r7, #12]
88 0008 B960 str r1, [r7, #8]
89 000a 7A60 str r2, [r7, #4]
2:float.c **** *result = *a * *b ;
91 .LM1:
92 000c FB68 ldr r3, [r7, #12]
93 000e 93ED007A flds s14, [r3]
94 0012 BB68 ldr r3, [r7, #8]
95 0014 D3ED007A flds s15, [r3]
96 0018 67EE277A fmuls s15, s14, s15
97 001c 7B68 ldr r3, [r7, #4]
98 001e C3ED007A fsts s15, [r3]
3:float.c **** }
100 .LM2:
101 0022 1437 adds r7, r7, #20
102 0024 BD46 mov sp, r7
103 @ sp needed
104 0026 5DF8047B ldr r7, [sp], #4
105 002a 7047 bx lr
import array
a = array.array("f", [3.0, 4.0, 0.0])
# Use same register R3 as float.cod
def mult(r0):
data(2, 0x93ED, 0x007A) # flds s14, [r3]
data(2, 0xD3ED, 0x007A, 0x67EE, 0x277A) #flds s15, [r3], fmuls s15, s14, s15
data(2, 0xC3ED, 0x007A) # fsts s15, [r3]
print(a[0] + a[1]) # Force a FP op to ensure FPU is enabled (?)
mult(a)
print(a)
no real help, but i modified your code to just load s15 and store it in array[1],
it doesn't crash, but what it prints is not comforting
7.0
array('f', [3.0, 1.085875e-19, 0.0])
Most alterations to the assembler code results in a crash ...
import array
def mult(r0):
data(2, 0xD3ED, 0x007A) # flds s15, [r3]
mult(a)
print(a)
7.0
Interesting: so it's updating the correct array element, but with garbage. There's clearly something we don't understand about the FPU. I notice that the assembler generated from C creates a 20 byte stack frame. It receives the pointer arguments in r0-r2 and shifts them into the stack frame before using them. I guess this is just compiler bahaviour: creating local variables automatically. But why does it reserve 20 bytes of stack for 12 bytes of data? Does the FPU expect to be provided with a scratchpad on the stack? I'll experiment by creating a stack frame at the outset.
<later> No joy with a stack frame.
In case anyone else is interested in pursuing this, I've figured out the problem. The assembler listing shows the bytes making up a 16 bit word in reverse order. Consider the line
In the ARM manual the T1 opcode is listed B480 and the correct data statement to cause that instruction to be executed is
The following code example works.
A final request. So far I've been unable to locate a document describing the FPU's instruction set down to the level of actual opcode binaries. I'd greatly appreciate a pointer
0000 80B4 push {r7}
data(2, 0xB480)
import array
def mult(r0):
data(2, 0xED93, 0x7A00) # flds s14, [r3]
data(2, 0xEDD3, 0x7A00) # flds s15, [r3]
data(2, 0xEE67, 0x7A27) # fmuls s15, s14, s15
data(2, 0xEDC3, 0x7A00) # fsts s15, [r3]
mult(a)
print(a)
I think that the document you want is titled: "ARM v7-M Architecture Reference Manual". It's a 916 page PDF.
I think you need to get an account on arm.com and then you can download it.
The URL I have is: https://silver.arm.com/download/ARM_and ... 7m_arm.pdf
It has each of the FPU opcode listed and broken down by bitfields as to what the bits in the opcode mean and how they map to registers, etc.
Thanks for that. Evidently there is more than one version of that document: the one I have, with exactly that title, is 705 pages and lacks the FPU info. Now downloaded.
