Problem compiling micropython on ubuntu
ExXec
Post by ExXec » Fri Apr 05, 2019 6:49 pm
Hey,
I get the error
arm-none-eabi-ld: error: uPY_TM4C123.axf uses VFP register arguments, /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/libm.a(lib_a-s_copysign.o) does not
when trying to compile micropython on my machine.
I run kubuntu latest version.
I read that this happens, because the libm is compiled as softfp and the rest as hardfp
Can I recompile the libm to work or are there simpler solutions to this?
On my windows machine, where I use WSL to compile the project, it works perfectly fine.
Thanks a lot!
-ExXec
ExXec
Re: Problem compiling micropython on ubuntu
Post by ExXec » Fri Apr 05, 2019 7:36 pm
I fixed it with another toolchain version:
sudo apt remove gcc-arm-none-eabi binutils-arm-none-eabi
sudo apt install gcc-arm-embedded
ThomasChr
Post by ThomasChr » Fri Apr 05, 2019 7:58 pm
See also: https://github.com/micropython/micropython/issues/4670
Looks like same problem and same solution :-)
