[SOLVED] Error when building Micropython
Posted: Sun May 05, 2019 3:39 pm
by shazz
I try to build MicroPython for Meowbit now that the source code is released but at the beginning of the compilation (and for any STM boards) on Ubuntu 18.10, I have this error:
sudo apt-get install gcc-arm-none-eabi binutils-arm-none-eabi
git clone --recurse-submodules https://github.com/KittenBot/micropython_meowbit.git
cd micropython_meowbit/
cd ports/stm32/
make BOARD=MEOWBIT V=1
Python ../../py/makeversionhdr.py build-MEOWBIT/genhdr/mpversion.h
GEN build-MEOWBIT/frozen_mpy.c
python ../../tools/mpy-tool.py -f -q build-MEOWBIT/genhdr/qstrdefs.preprocessed.h > build-MEOWBIT/frozen_mpy.c
usage: mpy-tool.py [-h] [-d] [-f] [-q QSTR_HEADER]
[-mlongint-impl {none,longlong,mpz}] [-mmpz-dig-size N]
files [files ...]
mpy-tool.py: error: too few arguments
make: *** [../../py/mkrules.mk:123: build-MEOWBIT/frozen_mpy.c] Error 2
make: *** Deleting file 'build-MEOWBIT/frozen_mpy.c'
Not sure what this mpy-tool.py is...
Looks like $(FROZEN_MPY_MPY_FILES) is empty..
Any idea ?
Re: Error when building Micropython
Posted: Sun May 05, 2019 5:27 pm
by quark
The mpy-tool.py extracts static strings, precalculatestheir hashes, and generate C code that can be embedded in the main program.
It seems your python binary didn't notice the -f -q ... flags for some reason. I'd try to debug it by writing a simple python program like:
[code]
# a.py
import sys
print(sys.argv)
[/code]
and run it using python a.py foo bar to test if foo bar gets printed out. If it does not, then try to use `which python`, and read its content to get some clues.
Posted: Sun May 05, 2019 6:05 pm
by shazz
it gives:
python a.py foo bar
['a.py', 'foo', 'bar']
which python
/usr/bin/python
python --version
Python 2.7.15+
Do I need to set python3 as the default version for python ?
Could it be a problem with
# make a list of all the .py files that need compiling and freezing
FROZEN_MPY_PY_FILES := $(shell find -L $(FROZEN_MPY_DIR) -type f -name '*.py' | $(SED) -e 's=^$(FROZEN_MPY_DIR)/==')
FROZEN_MPY_MPY_FILES := $(addprefix $(BUILD)/frozen_mpy/,$(FROZEN_MPY_PY_FILES:.py=.mpy))
Posted: Sun May 05, 2019 6:24 pm
by quark
Interesting. I'd just try running the command `make` runs:
and see how it breaks. python2 works for me. But you can try replacing python with python3. You can also try editing mpy-tool.py directly to narrow down the cause. Maybe the argparse module is somehow broken?
Posted: Sun May 05, 2019 6:31 pm
by shazz
Same result. With python2 and python3.
But doesn't it miss the arguments "file" before the > ?
from
files [files ...]
Posted: Sun May 05, 2019 6:36 pm
by shazz
Ok... I tried to compile from the
https://github.com/micropython repo and here it works. So I guess something is broken in the meowbit fork.
I'll ask the devs...
Posted: Sun May 05, 2019 10:14 pm
by jimmo
quark wrote: ↑Sun May 05, 2019 5:27 pm
That's actually makeqstrdefs.py / makeqstrdata.py.
mpy-tool is the tool that takes a bunch of .mpy files (generated by the .mpy cross compiler, which are python files compiled into bytecode) and includes them into your firmware image. This is really useful for stuff like drivers that you want to be part of ROM and not have to worry about putting on the filesystem.
The usual process for an STM32 board is that python code is placed in ports/stm32/boards/BOARD/modules, you point at this by overriding FROZEN_MPY_DIR in BOARD/mpconfigboard.mk, and this generates .mpy files that are then frozen. Otherwise it uses the default directory which is ports/stm32/modules.
For some reason, the meowbit team have removed the contents of all the files in ports/stm32/modules. (i.e. the files are there just empty). This means that the Makefile step that creates the intermediate .mpy files finds them, but generates no .mpy files. This means the makefile ends up passing no files to mpy-tool to generate the frozen object.
The quick solution just to get you moving is to add a file to ports/stm32/modules (e.g. meow.py) with a single line in it like 'x = 0' (anything that will generate some actual bytecode) and run the build again. Then eventually you can continue to add drivers (but do it in boards/MEOWBIT/modules and update mpconfigboard.mk as described above)
Posted: Mon May 06, 2019 12:01 am
by shazz
Thanks Jimmo!
Works like that!
I still wonder how it could compile for the Meowbit devs...
Re: [SOLVED] Error when building Micropython
Posted: Mon May 06, 2019 12:10 am
by jimmo
My guess is that they have some Python code (e.g. drivers) somewhere else (outside of the MicroPython tree), and they set an environment variable to point to that when they make their builds, overriding the default path. Might be worth following up with them?
Posted: Mon May 06, 2019 1:16 am
by shazz
Yeah, I asked them the question.... (one upon a lot
