Can't load external C modules in MP Windows
Posted: Thu Jun 13, 2019 3:50 am
I just created a C module that loads and works correctly on the unix port (WSL Ubuntu),
but when I create a windows exe and try to load it, I get:
I cross-compiled on WSL for Windows, and seems the C module source was picked up correctly, and I see the module directory
under build/
I had a similar problem with frozen modules earlier that turned out to be missing path name in sys.path, so I checked that:
I see the null path at the beginning, so sys.path is alright.
Thanks!
PP
>>> import mpmymod
ImportError: no module named 'mpmymod'
under build/
$ make CROSS_COMPILE=i686-w64-mingw32- USER_C_MODULES=. CFLAGS_EXTRA="-DMODULE_MPMYMOD_ENABLED=1"
Including User C Module from ./mpmymod
mkdir -p build/genhdr
GEN build/genhdr/mpversion.h
GEN build/genhdr/moduledefs.h
GEN build/genhdr/qstr.i.last
GEN build/genhdr/qstr.split
GEN build/genhdr/qstrdefs.collected.h
QSTR updated
LINK micropython.exe
text data bss dec hex filename
312240 3644 8732 324616 4f408 micropython.exe
>>> import sys
>>> print (sys.path)
['', 'C:/Users/pp/.micropython/lib:/usr/lib/micropython']
Thanks!
PP
