EFM32 port
nteolane
EFM32 port
Post by nteolane » Tue Oct 01, 2019 8:33 am
I would like to port Micropython on the Silicon Labs EFM32 MCU, specifically the EFM32LG series.
Has this already been done? Maybe some proof of concept code I could start with?
Where should I start?
Is starting from ports/mininal a good idea?
Thanks in advance for your guidance!
Best regards,
Nicolas
Re: EFM32 port
Post by jimmo » Wed Oct 02, 2019 1:31 pm
I'm not aware of any ports to the LG family, but it does appear to have enough RAM/ROM to run MicroPython well.
Yep, ports/minimal is a good start -- the STM32-specific parts are quite obvious and it gives you a good idea of what you need to replace (mainly a uart driver).
ports/bare-arm is also an option, it has no drivers at all though, so you'll need some other way to see that things are working (i.e. SWD).
