Page 2 of 2
Re: Question about the dht module (and maybe some more)
Posted: Sat Nov 30, 2019 4:17 pm
by Roberthh
The data sheet (at least the one I have) shows an Pull-Up resistor of 1KOhm. That is good for longish wires. The internal pull-up of the ESP8266 has a value of at least 30kOhm. That is good for a desk test, but not sufficient for longer wires. So adding an external pull-up is recommended.
Posted: Sat Nov 30, 2019 7:18 pm
by MostlyHarmless
To summarize, first
commit 033c32e fixed a glitch in i2c by switching the pin to IN when OPEN_DRAIN+HIGH is requested, which apparently broke some use cases of DHT22s. Then
commit 18d3a5d brought back the previous behavior of
mp_hal_pin_od_high() as
mp_hal_pin_od_high_dht().
Note that since commit 033c32e the esp8266 port's behavior of
mp_hal_pin_od_high() is identical to
pin_set() when in OPEN_DRAIN mode . Note also that the esp32 port behaves different right now as it really uses OPEN_DRAIN mode and just toggles the pin's output value without changing IN/OUT at all.
I think it would be bad to leave the two ports in incompatible default behavior. My proposal is to make the esp8266 port use
mp_hal_pin_od_high() by default and add a flag that lets the user specify to use
mp_hal_pin_od_high_dht() instead. Something like
flags=ALT_HIGH. More flags can be added if we encounter more DHT22 flavors in the future.
Going to create a new branch with that implemented.
Regards, Jan
Posted: Sat Nov 30, 2019 7:52 pm
by MostlyHarmless
Roberthh wrote: ↑Sat Nov 30, 2019 4:17 pm
The one I am using had an on-board 5K1 pull-up, which I since removed for testing purposes. Works with or without it. These things really seem to be all over the map. Using two different boards and two different sensors one apparently gets 5 different behaviors.
Regards, Jan
Posted: Sat Nov 30, 2019 9:32 pm
by MostlyHarmless
Posted: Sun Dec 01, 2019 7:27 pm
by MostlyHarmless
Forget that.
I combined it all into one commit, added the necessary documentation changes and create a pull request.
https://github.com/micropython/micropyt ... 49f5ef85dd
Best Regards, Jan
Posted: Sat Apr 02, 2022 12:05 am
by random-builder
Another solution for a similar problem (random timeout errors in DHT):
re-implement driver in viper for total control of DHT protocol parameters.
https://github.com/micropython/micropyt ... 1086420730
