drivers/dht improvements (take 2)
MostlyHarmless
Re: drivers/dht improvements (take 2)
Post by MostlyHarmless » Sat Jan 04, 2020 2:11 pm
tve wrote:
Sat Jan 04, 2020 1:32 am
you have been using a model where the driver exports an `ameasure` method that calls async delay functions inside. In my drivers I have instead provided a `start` method that starts the data acquisition and returns the expected time it will take and then a second `read` method that reads the result assuming it's ready and returns an error if it's not. The rationale for my design is that this model lets the caller decide which form of delay function to call. Is that not preferable?
It is perfectly preferable. Especially since it does not restrict itself to one type of multitasking framework. I like that.
What format and unit is it that your `start` method returns the desired delay? It would be good to coordinate things like that across drivers.
Thanks, Jan
Online
tve
Post by tve » Sat Jan 04, 2020 11:19 pm
The start() or convert() method (I can't decide what the name should be) returns milliseconds to wait. I picked that for expediency more than anything else. Less than one ms and it seems better to just sleep right there...
I believe where "my" model breaks is when there are multiple steps or multiple options. For example, with the Si7021 temp/hum sensor one can start a temperature conversion and then read the result. One can also separately start a humidity conversion and read that result, plus the temperature which gets captured as well (used internally to compensate the humidity). That's still simple, but the start_this() and start_that() methods begin to accumulate.
I tend to hack up drivers I find to cut out the 90% I don't need and to make sure the 10% I do need work the way I expect, so I don't encounter complex situations that often.
Another tricky example is a driver for UART based devices, such as many particle matter sensors. These don't really have any predictable timing. I ended up providing a read() method that internally processes however many chars are available and returns None when no complete packet has arrived yet or the data when it has. But that's unsatisfactory also because it means it needs to be called all the time which makes it difficult to sleep in low power state in the main loop.
MostlyHarmless
Post by MostlyHarmless » Sun Jan 05, 2020 3:20 am
Agreed, ms makes sense. Will change the model tomorrow.
How about start(CONV_TEMP | CONV_HUM | ...) ?
Yeah, I got something similar here. A NEO-6M GPS module. It sends NMEA on UART, and then later comes the PPS. Like "at the tone it is <time> ... BEEP." And it does that all the time, not just when asked for. The problem with that is that if you don't constantly drain the UART, you get garbage on the first read because the UART's receive buffer has overflown. So I have one async task constantly reading the data and remembering the last $GRMC record seen. Then when one wants the time one just waits for the rising edge of the PPS and decodes the last record. The task reading the UART is using a uasyncio.StreamReader(), which works quite well.
Regards, Jan
MostlyHarmless
Post by MostlyHarmless » Sun Jan 05, 2020 4:59 pm
Changed the driver accordingly. Here is the new implementation that removes the uasyncio dependency.
The example, added to the esp8266 and esp32 Quickref documention reads:
Separate methods to send the start signal and receive the result
exist to minimize blocking in event loops. This is a uasyncio
based example printing the sensor data every 2 seconds:
    import dht
    import uasyncio as asyncio
    async def report_dht_data(d):
            await asyncio.sleep(2)
                wait_ms = d.start()
                await asyncio.sleep_ms(wait_ms)
                d.receive()
            except Exception as ex:
                print("error: {}".format(ex))
                continue
            print("temp: {}°C humi: {}%RH".format(d.temperature(),
                                                  d.humidity()))
    d = dht.DHT22(machine.Pin(4))
    loop.create_task(report_dht_data(d))
    loop.run_forever()
Everything is rebased on current master and tested on esp8266 and esp32. Thanks again for the suggestion, @tve.
Regards, Jan
mcauser
Post by mcauser » Fri Jan 17, 2020 3:27 am
The AM2320 is an upgrade of the DHT22 / AM2302, and it supports both the old 1-wire interface and I2C.
https://github.com/mcauser/micropython-am2320
Same goes for the tiny DHT12, which is an upgrade of the DHT11, and adds I2C too.
https://github.com/mcauser/micropython-dht12
These could do with some asyncio.
Post by pythoncoder » Fri Jan 17, 2020 9:31 am
There is nothing wrong with
wait_ms = d.start()
d.receive()
however if I were writing the device driver I'd either provide an awaitable receive method so you could write
await d.receive()
or make the class an awaitable class. Then you'd just have
await d
Either approach hides the detail of how the delay is performed (enabling it perhaps to be changed at some point) without affecting application behaviour.
MostlyHarmless
Post by MostlyHarmless » Fri Jan 17, 2020 1:02 pm
wait_ms = d.start()
d.receive()
await d.receive()
await d
The initial proposal did
await d.ameasure()
I changed it to this separate start+receive model based on the discussion with @tve above. While an awaitable class certainly is more convenient to someone, using asyncio already, it makes it rather difficult to use in an application with a different multiplexing model.
Regards, Jan
MostlyHarmless
Post by MostlyHarmless » Fri Jan 17, 2020 1:30 pm
Unless I missed something there seems to be only a single time.sleep_ms(2) in your code. Not sure where that delay is coming from but this is barely enough time for uasyncio to switch to another task and back. What happens if the other task takes a couple milliseconds? What happens if that other task performs I2C communication itself, like updating an OLED display? The latter one is especially hard to stress test.
Regards, Jan
jedie
Post by jedie » Fri Jan 17, 2020 3:35 pm
    import dht
                wait_ms = d.start()
                d.receive()
                continue
                                                  d.humidity()))
    loop.run_forever()
I would move the await asyncio.sleep(2) after the print() ... So you will get the temperature directly after start ;)
MostlyHarmless
Post by MostlyHarmless » Fri Jan 17, 2020 3:52 pm
From a cold boot the DHT sensor needs some time to stabilize and become ready. If you try to query it too soon after power on all you get is a ETIMEDOUT. You might be able to move the two second sleep to the end of the loop but then end up needing another, smaller sleep before entering the loop.
