IDE setup for micropython development
nagylzs
Post by nagylzs » Wed Dec 18, 2019 3:12 pm
I'm trying to setup Visual Studio Code under Linux, to be used for MicroPython development with esp32.
I'm using this directory structure:
 |- esp-idf
 |- micropython
 |- modules
 |- xtensa-esp23-elf
Here, "micropython" contains the micropython source code, and the "modules" directory is for custom external C modules ( https://docs.micropython.org/en/latest/ ... dules.html )
I have created this c_cpp_properties.json file:
    "configurations": [
            "name": "Linux",
            "includePath": [
                "${workspaceFolder}/esp-idf/components/soc/esp32/include/**",
                "${workspaceFolder}/esp-idf/micropython/**"
            "defines": [],
	    "compilerPath": "${workspaceFolder}/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc",
            "cStandard": "c11",
            "cppStandard": "c++14",
            "intelliSenseMode": "clang-x64"
    "version": 4
I'm getting errors about undefined identifiers. They are mostly MP_QSTR_* identifiers. I'm not sure how hey work, they are actually undefined. They must have been generated somehow. The basic example for external C modules also contains this:
MP_QSTR_example
What are these? Are they some kind of generated macros? Can I make VS code accept them?
I could also use a different IDE if it works better (although I'm already familiar with VS code).
nagylzs
Re: IDE setup for micropython development
Post by nagylzs » Wed Dec 18, 2019 3:21 pm
Also, compilation errors are not clickable.
Example:
https://imgur.com/EPCYVnE
It might be because in the error message, the path is relative to the micropython/ports/esp32 build dir, I'm not sure.
