V1.12 RuntimeError: name too long
RWLTOK
Post by RWLTOK » Thu Jan 02, 2020 5:58 pm
I just built and installed v1.12 on a PYBV11 board. This is what comes up after power up or a ctrl-d.
Thoughts?
MPY: sync filesystems
MPY: soft reboot
MicroPython v1.12-35-g10709846f on 2020-01-02; PYBv1.1 with STM32F405RG
Rich
PS:
I deleted my micropython installation and redid the git clone bla bla bla. Here is the output of the unix port:
MicroPython v1.12-35-g10709846f on 2020-01-02; linux version
I don't get the error when I run the unix port.
RWLTOK
Re: V1.12 RuntimeError: name too long
Post by RWLTOK » Thu Jan 02, 2020 7:50 pm
Found the issue. I received a new clone pyboard V1.1 from China. When I restored a known working micropython image I got the same error so I knew it was not an issue with the build. By restoring the local file system (orange green LED boot), the error went away. Perhaps this will help someone.
Rich
Online
Post by jimmo » Fri Jan 03, 2020 5:37 am
There was a fix in 1.12 that had something to do with catching cases where names were too long. https://github.com/micropython/micropython/pull/5105 That might be related.
Likely you had something in main.py, which is why a filesystem reset made the problem go away.
