Slowing things down
RWLTOK
Slowing things down
Post by RWLTOK » Sat Feb 22, 2020 11:22 pm
I am trying the slow down my STM32L452RE application.
No luck with using the pyb.freq() function as it is not supported in that port currently. Is anyone aware of a fork that may have this implemented. Everything is hardcoded in system_stm32.c and it appears no user serviceable parts inside.
Anyone every taken a stab at implementing this function?
>>> pyb.freq(8000000)
NotImplementedError: machine.freq set not supported yet
Thanks for looking.
Rich
Re: Slowing things down
Post by deshipu » Sun Feb 23, 2020 9:21 am
Why do you need it to be slower? What are you trying to do?
Usually you do this by using some delays or timers.
chrismas9
Post by chrismas9 » Mon Feb 24, 2020 1:09 pm
If you want to slow it down permanently, maybe to save power, you could edit the PLL values in moconfigboard.h and rebuild it. I suggest running the clock config utility in stm32cubemx to find the right values. Make sure the USB clock is still 48MHz if you are using USB.
RWLTOK
Post by RWLTOK » Sun Mar 01, 2020 6:19 am
Thanks for the responses. I have played with the PLLs to slow things down. The goal is to save as much power as possible. I would like to run the MSI clock at 2MHz. In this low power mode, there will be no USB. I am not looking forward to debugging in this mode.
