I try to freeze some modules. Some of them live in /dist-packages. During the build I get a lot of error messages like:
build-GENERIC/frozen_content.c:5764:48: error: expected '=', ',', ';', 'asm' or '__attribute__' before '-' token
STATIC const mp_rom_obj_t const_table_data_dist-packages_shutil__lt_module_gt__rmtree[1] = {
The '^' is pointing at the '-'
If I rename the path to /distpackages it works. So the '-' is the source of the faults and that is intended to be like this?
Just asking for confirmation.
Thanks.
'-' in frozen module path not allowed
Re: '-' in frozen module path not allowed
Nevermind - my fault. Problem was that /dist-packages is not a module.
Yep. This could be handled better by the freezing process (it should escape special characters when generating the identifier names), but in this case pretty much anyhting that isn't valid as a C identifier (including "-") is also not valid in a module/package name in Python.
