Builtin modules are loaded at the point of importing them
pulkin
Post by pulkin » Fri Feb 28, 2020 10:41 pm
When I turn debug messages on I see the following:
MicroPython v1.11-697-g7b18c0b93-dirty on 2020-02-28; A9/A9G module with RDA8955
>>> import sys
import name 'sys' level=0
__import__:
  'sys'
  None
  None
  None
  0
Module already loaded
This means that there is no way for the user to override this name. How do I fix it?
Re: Builtin modules are loaded at the point of importing them
Post by jimmo » Fri Feb 28, 2020 11:52 pm
sys is a bit different to the other built-in modules like uos and umachine where "import os" first tries os.py then builtin uos -- it's actually called sys, not usys.
So there's no way to provide a custom sys.py
What are you trying to do?
pulkin
Post by pulkin » Sat Feb 29, 2020 9:38 pm
It is not only sys: every built-in module is loaded.
Post by jimmo » Sat Feb 29, 2020 10:27 pm
I don't really understand your question then, what are you trying to do?
If you want a custom "os" you can write os.py.
pulkin
Post by pulkin » Sat Feb 29, 2020 11:45 pm
I believe the problem is that you cannot override the built-in module. The typical way one would do it is to manipulate sys.path before importing the module. In my case, however, that does not help: whatever import order is the built-in module is always preffered/loaded. I.e. there is no way to import, for example, os.py or machine.py. I traced down the reason down to the output in the header: all built-in modules are loaded already at startup, whatever that means. I am wondering what is the reason for such behavior: the ESP8266 port perfectly allows this kind of hack.
Post by jimmo » Mon Mar 02, 2020 1:35 am
This is definitely true of `sys`, but not `uos`, `umachine`, etc and many other built-in modules.
Here's an example interaction of overriding built-in os.
$ cat /tmp/os.py
print('import os.py')
def fake_os():
  print('hi')
$ pyboard --device /dev/ttyUSB0 -f cp /tmp/os.py :
cp /tmp/os.py :os.py
$ miniterm /dev/ttyUSB0 115200
--- Miniterm on /dev/ttyUSB0  115200,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
MPY: soft reboot
MicroPython v1.12-210-g1993c8cf9 on 2020-03-02; TinyPICO with ESP32-PICO-D4
>>> import os
import os.py
>>> os.fake_os()
hi
>>> import uos
>>> uos.uname()
(sysname='esp32', nodename='esp32', release='1.12.0', version='v1.12-210-g1993c8cf9 on 2020-03-02', machine='TinyPICO with ESP32-PICO-D4')
>>> os.fake_os()
hi
Can you provide a similar example?
Post by jimmo » Mon Mar 02, 2020 1:40 am
I just noticed you're on ESP8266 not ESP32, but tested it here on an ESP8266 too and same result.
pulkin
Post by pulkin » Wed Mar 04, 2020 1:07 pm
Right, what I am saying is that I have a port
https://github.com/pulkin/micropython/t ... ts/gprs_a9
where I have to make it behave like you demonstarted. At the firmware level.
Post by jimmo » Wed Mar 04, 2020 1:20 pm
This feature is called "weak links" -- the idea is that "os" is a weak link to "uos". (The name comes from "weak symbol" in a linker).
Might be a good idea to rebase onto the current master (looks like your fork is up to about mid-September 2019). The way the foo -> ufoo imports works changed in mid-October 2019.
(It used to be that each port managed its own set of weak links (e.g. look at stm32/mpconfigport.h for the MICROPY_PORT_BUILTIN_MODULE_WEAK_LINKS definition). This provides the fallback registration for (e.g.) "os" to "uos" (if os.py isn't found). Since late last year, it was just changed that when MICROPY_MODULE_WEAK_LINKS is enabled, any time you import a module named "foo" it will try "ufoo" (i.e. it always just tries to prefix a "u'). See https://github.com/micropython/micropython/pull/5241
Hopefully the above explains everything you need...
Note that because the "sys" module is named "sys" (not "usys"), this is not possible for "sys".
pulkin
Post by pulkin » Wed Mar 04, 2020 4:11 pm
To verify my understanding: does this mean that up-to-date ESP8266 firmware allows importing files named os.py but will not import uos.py?
