gc_alloc(16 bytes -> 1 blocks)
gc_alloc(82182770)
malloc 16 : 82182770
gc_alloc(82182780)
malloc 16 : 82182780
make_function_from_raw_code 8827e69c
gc_alloc(82182790)
malloc 16 : 82182790
mp_globals_get: result 0p82300ff0
calling function 82182790(n_args=0, n_kw=0, args=0)
Input n_args: 0, n_kw: 0
Input pos args: 0:
Input kw args: 0:
gc_alloc(36 bytes -> 3 blocks)
gc_alloc(821827a0)
malloc 36 : 821827a0
Calling: n_pos_args=0, n_kwonly_args=0
821827c4:
821827b4: 0 0 0 0
import name 'os' level=0
__import__:
'os'
None
None
None
0
mp_map_lookup: map 82300fa0 lookup_kind 0 is_fixed 0
mp_map_lookup: map 88279044 lookup_kind 0 is_fixed 1
Module not yet loaded
Processing module: os
Previous path: ==
stat os: 0
stat /lib/os: 0
stat //os: 0
Current path: //os.mpy
mp_map_lookup: map 88279050 lookup_kind 0 is_fixed 1
mp_map_lookup: map 882805c8 lookup_kind 0 is_fixed 1
store name os <- 8828059c
mp_map_lookup: map 82300ff4 lookup_kind 1 is_fixed 0
mp_map_rehash(82300ff4): 1 -> 2
gc_alloc(821827d0)
malloc 16 : 821827d0
gc_free(82182750)
free 82182750
mp_load_name: name os
mp_load_name: looking up in globals os
load global os
mp_map_lookup: map 82300ff4 lookup_kind 0 is_fixed 0
load global os OK
load method 8828059c.mount
load global os
load global os OK
load attr 8828059c.internal_flash
load method 8828059c.internal_flash
call method (fun=8827d864, self=0, n_args=2, n_kw=0, args=821827b4)
calling function 8827d864(n_args=2, n_kw=0, args=821827bc)
mp_map_lookup: map 822787f8 lookup_kind 0 is_fixed 1
mp_obj_class_lookup: Looking up mount in internal_flash
mp_map_lookup: map 88280724 lookup_kind 0 is_fixed 1
mp_obj_class_lookup: Returning: <function>
gc_alloc(82182750)
malloc 16 : 82182750
load method 882806c8.mount
call method (fun=882804e4, self=0, n_args=2, n_kw=0, args=82278770)
calling function 882804e4(n_args=2, n_kw=0, args=82278778)
gc_alloc(821827e0)
malloc 16 : 821827e0
gc_alloc(8 bytes -> 1 blocks)
gc_alloc(821827f0)
malloc 8 : 821827f0
load method 882806c8.stat
mp_obj_class_lookup: Looking up stat in internal_flash
call method (fun=88280574, self=0, n_args=1, n_kw=0, args=82278968)
calling function 88280574(n_args=1, n_kw=0, args=82278970)
gc_alloc(82182800)
malloc 16 : 82182800
gc_alloc(12 bytes -> 1 blocks)
gc_alloc(82182810)
malloc 12 : 82182810
gc_alloc(82182820)
malloc 16 : 82182820
gc_alloc(82182830)
malloc 8 : 82182830
gc_alloc(82182840)
malloc 16 : 82182840
gc_alloc(82182850)
malloc 12 : 82182850
gc_alloc(32 bytes -> 2 blocks)
gc_alloc(82182860)
malloc 32 : 82182860
MicroPython v1.11-703-g892cf5203-dirty on 2020-03-07; A9/A9G module with RDA8955
>>> import parser
gc_alloc(14 bytes -> 1 blocks)
gc_alloc(82182880)
malloc 14 : 82182880
gc_alloc(82182890)
malloc 16 : 82182890
gc_alloc(84 bytes -> 6 blocks)
gc_alloc(821828a0)
malloc 84 : 821828a0
gc_alloc(20 bytes -> 2 blocks)
gc_alloc(82182900)
malloc 20 : 82182900
gc_alloc(82182920)
malloc 32 : 82182920
gc_alloc(512 bytes -> 32 blocks)
gc_alloc(82182940)
malloc 512 : 82182940
gc_alloc(128 bytes -> 8 blocks)
gc_alloc(82182b40)
malloc 128 : 82182b40
gc_alloc(82182bc0)
malloc 128 : 82182bc0
QSTR: add hash=3170 len=6 data=parser
gc_alloc(96 bytes -> 6 blocks)
gc_alloc(82182c40)
malloc 96 : 82182c40
QSTR: allocate new pool of size 20
gc_alloc(136 bytes -> 9 blocks)
gc_alloc(82182ca0)
malloc 136 : 82182ca0
gc_free(0)
free 0
m_realloc_maybe: realloc 82182ca0, 20, 2182622368 : 82182ca0
gc_free(82182940)
free 82182940
gc_free(82182b40)
free 82182b40
gc_free(82182890)
free 82182890
gc_free(82182920)
free 82182920
gc_free(82182900)
free 82182900
gc_free(821828a0)
free 821828a0
gc_alloc(48 bytes -> 3 blocks)
gc_alloc(82182890)
malloc 48 : 82182890
gc_alloc(821828c0)
malloc 12 : 821828c0
gc_alloc(821828d0)
malloc 32 : 821828d0
gc_alloc(64 bytes -> 4 blocks)
gc_alloc(821828f0)
malloc 64 : 821828f0
gc_alloc(0 bytes -> 0 blocks)
malloc 0 : 0
gc_alloc(24 bytes -> 2 blocks)
gc_alloc(82182930)
malloc 24 : 82182930
malloc 0 : 0
assign byte code: code=82182930 len=0 flags=0
gc_free(0)
free 0
gc_free(821828f0)
free 821828f0
gc_free(82182ca0)
free 82182ca0
gc_free(821828d0)
free 821828d0
gc_free(82182890)
free 82182890
make_function_from_raw_code 821828c0
gc_alloc(82182890)
calling function 82182890(n_args=0, n_kw=0, args=0)
Input pos args: 0:
Input kw args: 0:
gc_alloc(28 bytes -> 2 blocks)
gc_alloc(821828a0)
malloc 28 : 821828a0
821828bc:
821828b4: 0 0
import name 'parser' level=0
__import__:
'parser'
None
None
None
0
Processing module: parser
Previous path: ==
call method (fun=88280574, self=0, n_args=1, n_kw=0, args=822785f8)
calling function 88280574(n_args=1, n_kw=0, args=82278600)
gc_alloc(821828d0)
malloc 16 : 821828d0
gc_alloc(821828e0)
malloc 12 : 821828e0
stat parser: 0
gc_alloc(821828f0)
malloc 16 : 821828f0
gc_alloc(10 bytes -> 1 blocks)
gc_alloc(82182900)
malloc 10 : 82182900
call method (fun=88280574, self=0, n_args=1, n_kw=0, args=822785e0)
calling function 88280574(n_args=1, n_kw=0, args=822785e8)
gc_alloc(82182950)
malloc 48 : 82182950
Current path: parser.py
mp_map_lookup: map 82300fa0 lookup_kind 1 is_fixed 0
gc_alloc(82182910)
malloc 8 : 82182910
gc_alloc(82182920)
malloc 16 : 82182920
gc_alloc(82182980)
malloc 8 : 82182980
mp_map_lookup: map 82182924 lookup_kind 1 is_fixed 0
gc_alloc(82182990)
malloc 32 : 82182990
gc_alloc(821829b0)
malloc 16 : 821829b0
gc_alloc(821829c0)
malloc 10 : 821829c0
mp_map_lookup: map 88277938 lookup_kind 0 is_fixed 1
gc_alloc(821829d0)
malloc 16 : 821829d0
gc_alloc(821829e0)
malloc 10 : 821829e0
load method 882806c8.open
mp_obj_class_lookup: Looking up open in internal_flash
call method (fun=882809c0, self=0, n_args=2, n_kw=0, args=822785d8)
calling function 882809c0(n_args=2, n_kw=0, args=822785e0)
mp_map_lookup: map 82278540 lookup_kind 0 is_fixed 1
gc_alloc(821829f0)
malloc 8 : 821829f0
QSTR: add hash=63877 len=9 data=parser.py
gc_alloc(82182a00)
malloc 84 : 82182a00
gc_alloc(82182a60)
malloc 20 : 82182a60
gc_alloc(82182a80)
malloc 32 : 82182a80
store attr 82182910.__file__ <- d46
mp_map_rehash(82182924): 1 -> 2
gc_alloc(82182aa0)
malloc 16 : 82182aa0
gc_free(82182980)
free 82182980
gc_alloc(82182ca0)
malloc 512 : 82182ca0
gc_alloc(82182ab0)
malloc 128 : 82182ab0
mp_map_lookup: map 822785d0 lookup_kind 0 is_fixed 0
gc_alloc(82182b30)
malloc 136 : 82182b30
QSTR: add hash=44804 len=4 data=SKIP
m_realloc_maybe: realloc 82182b30, 156, 0 : 82182b30
m_realloc_maybe: realloc 82182b30, 128, 2182622000 : 82182b30
gc_alloc(82182ea0)
malloc 136 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 152, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 172, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 184, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 200, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 216, 2182622880 : 82182ea0
QSTR: add hash=29971 len=2 data=\
m_realloc_maybe: realloc 82182ea0, 236, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 248, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 264, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 280, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 292, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 308, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 324, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 340, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 356, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 376, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 388, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 404, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 420, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 432, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 448, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 464, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 480, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 496, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 516, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 528, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 544, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 560, 2182622880 : 82182ea0
m_realloc_maybe: realloc 82182ea0, 596, 2182622880 : 82182ea0
gc_free(0)
free 0
m_realloc_maybe: realloc 82182ea0, 592, 2182622880 : 82182ea0
gc_free(82182ca0)
free 82182ca0
gc_free(82182ab0)
free 82182ab0
gc_free(82182990)
free 82182990
gc_free(82182a80)
free 82182a80
gc_free(82182a60)
free 82182a60
gc_free(82182a00)
free 82182a00
gc_alloc(82182980)
malloc 48 : 82182980
gc_alloc(82182a00)
malloc 12 : 82182a00
gc_alloc(82182a10)
malloc 32 : 82182a10
gc_alloc(82182a30)
malloc 64 : 82182a30
gc_alloc(80 bytes -> 5 blocks)
gc_alloc(82182ab0)
gc_realloc(82182a10 -> 82182ab0)
gc_free(82182a10)
m_realloc: realloc 82182a10, 80 : 82182ab0
gc_alloc(82182ca0)
malloc 64 : 82182ca0
gc_alloc(228 bytes -> 15 blocks)
gc_alloc(82182ce0)
malloc 228 : 82182ce0
malloc 0 : 0
assign byte code: code=82182ce0 len=0 flags=0
gc_free(82182ca0)
free 82182ca0
gc_free(82182a30)
free 82182a30
gc_free(82182ea0)
free 82182ea0
gc_free(82182b30)
free 82182b30
gc_free(82182ab0)
free 82182ab0
gc_free(82182980)
free 82182980
make_function_from_raw_code 82182a00
gc_alloc(82182980)
malloc 16 : 82182980
mp_globals_get: result 0p82182920
calling function 82182980(n_args=0, n_kw=0, args=0)
Input pos args: 0:
Input kw args: 0:
gc_alloc(56 bytes -> 4 blocks)
gc_alloc(82182a10)
malloc 56 : 82182a10
82182a3c:
82182a24: 0 0 0 0 0 0
mp_load_name: name compile
mp_load_name: looking up in globals compile
load global compile
mp_map_lookup: map 82182924 lookup_kind 0 is_fixed 0
load global compile OK
mp_map_lookup: map 8827afbc lookup_kind 0 is_fixed 1
load global compile
calling function 8827acf8(n_args=3, n_kw=0, args=82182a28)
gc_alloc(82182990)
malloc 16 : 82182990
gc_alloc(82182ab0)
malloc 84 : 82182ab0
gc_alloc(82182a50)
malloc 20 : 82182a50
gc_alloc(82182a70)
malloc 32 : 82182a70
gc_alloc(821829a0)
malloc 8 : 821829a0
gc_alloc(82182dd0)
malloc 512 : 82182dd0
gc_alloc(82182b10)
malloc 128 : 82182b10
gc_free(0)
free 0
gc_alloc(82182a90)
malloc 16 : 82182a90
gc_alloc(82182b90)
malloc 16 : 82182b90
gc_alloc(82182ba0)
malloc 12 : 82182ba0
gc_alloc(82182bb0)
malloc 12 : 82182bb0
gc_alloc(82182ca0)
gc_realloc(82182bb0 -> 82182ca0)
gc_free(82182bb0)
m_realloc_maybe: realloc 82182bb0, 24, 2182622368 : 82182bb0
mp_load_name: name SyntaxError
mp_load_name: looking up in globals SyntaxError
load global SyntaxError
mp_map_lookup: map 4 lookup_kind 0
