Adding External C Modules with external functions to mp as a library
cduran
Post by cduran » Tue Mar 10, 2020 11:29 pm
I have a unique problem that I am trying to solve. I'm currently building mp 1.12 as a library which I then import into my existing project. My project is arm based and has no OS so I'm using the minimal build as a start.
So far I'm able to build an mp lib and run script strings just fine. Where I'm having problems is adding a C module to the library.
I am following the instructions here, with one exception: http://docs.micropython.org/en/latest/d ... dules.html
The exception is that the only function in the module requires a lot of libraries and code from the project I am added mp to. So in my case this code:
// This is the function which will be called from Python as example.add_ints(a, b).
STATIC mp_obj_t example_add_ints(mp_obj_t a_obj, mp_obj_t b_obj) {
    // Extract the ints from the micropython input objects
    int a = mp_obj_get_int(a_obj);
    int b = mp_obj_get_int(b_obj);
    // Calculate the addition and convert to MicroPython object.
    return mp_obj_new_int(a + b);
is replaced with a header file containing
STATIC mp_obj_t example_add_ints(mp_obj_t a_obj, mp_obj_t b_obj);
The body of this function is part of my code. The library builds with no errors, but when I build my project I get an undefined reference error for the function in my module. Any ideas, suggestions?
I've included my following
mpconfigport.h
micropython.mk
helpers.h - module code
helpers.c
Here's my Makefile for the library:
#include <stdint.h>
// options to control how MicroPython is built
// You can disable the built-in MicroPython compiler by setting the following
// config option to 0.  If you do this then you won't get a REPL prompt, but you
// will still be able to execute pre-compiled scripts, compiled with mpy-cross.
#define MICROPY_ENABLE_COMPILER     (1)
#define MICROPY_QSTR_BYTES_IN_HASH  (1)
#define MICROPY_QSTR_EXTRA_POOL     mp_qstr_frozen_const_pool
#define MICROPY_ALLOC_PATH_MAX      (256)
#define MICROPY_ALLOC_PARSE_CHUNK_INIT (16)
#define MICROPY_EMIT_X64            (0)
#define MICROPY_EMIT_THUMB          (0)
#define MICROPY_EMIT_INLINE_THUMB   (0)
#define MICROPY_COMP_MODULE_CONST   (0)
#define MICROPY_COMP_CONST          (0)
#define MICROPY_COMP_DOUBLE_TUPLE_ASSIGN (0)
#define MICROPY_COMP_TRIPLE_TUPLE_ASSIGN (0)
#define MICROPY_MEM_STATS           (0)
#define MICROPY_DEBUG_PRINTERS      (0)
#define MICROPY_ENABLE_GC           (1)
#define MICROPY_GC_ALLOC_THRESHOLD  (0)
#define MICROPY_REPL_EVENT_DRIVEN   (0)
#define MICROPY_HELPER_REPL         (1)
#define MICROPY_HELPER_LEXER_UNIX   (0)
#define MICROPY_ENABLE_SOURCE_LINE  (0)
#define MICROPY_ENABLE_DOC_STRING   (0)
#define MICROPY_ERROR_REPORTING     (MICROPY_ERROR_REPORTING_TERSE)
#define MICROPY_BUILTIN_METHOD_CHECK_SELF_ARG (0)
#define MICROPY_PY_ASYNC_AWAIT      (0)
#define MICROPY_PY_BUILTINS_BYTEARRAY (0)
#define MICROPY_PY_BUILTINS_DICT_FROMKEYS (0)
#define MICROPY_PY_BUILTINS_MEMORYVIEW (0)
#define MICROPY_PY_BUILTINS_ENUMERATE (0)
#define MICROPY_PY_BUILTINS_FILTER  (0)
#define MICROPY_PY_BUILTINS_FROZENSET (0)
#define MICROPY_PY_BUILTINS_REVERSED (0)
#define MICROPY_PY_BUILTINS_SET     (0)
#define MICROPY_PY_BUILTINS_SLICE   (0)
#define MICROPY_PY_BUILTINS_PROPERTY (0)
#define MICROPY_PY_BUILTINS_MIN_MAX (0)
#define MICROPY_PY_BUILTINS_STR_COUNT (0)
#define MICROPY_PY_BUILTINS_STR_OP_MODULO (0)
#define MICROPY_PY___FILE__         (0)
#define MICROPY_PY_GC               (0)
#define MICROPY_PY_ARRAY            (0)
#define MICROPY_PY_ATTRTUPLE        (0)
#define MICROPY_PY_COLLECTIONS      (0)
#define MICROPY_PY_MATH             (0)
#define MICROPY_PY_CMATH            (0)
#define MICROPY_PY_IO               (0)
#define MICROPY_PY_STRUCT           (0)
#define MICROPY_PY_SYS              (0)
#define MICROPY_MODULE_FROZEN_MPY   (1)
#define MICROPY_CPYTHON_COMPAT      (0)
#define MICROPY_LONGINT_IMPL        (MICROPY_LONGINT_IMPL_NONE)
#define MICROPY_FLOAT_IMPL          (MICROPY_FLOAT_IMPL_NONE)
#define MODULE_HELPERS_ENABLED		(1)
// type definitions for the specific machine
#define MICROPY_MAKE_POINTER_CALLABLE(p) ((void*)((mp_uint_t)(p) | 1))
// This port is intended to be 32-bit, but unfortunately, int32_t for
// different targets may be defined in different ways - either as int
// or as long. This requires different printf formatting specifiers
// to print such value. So, we avoid int32_t and use int directly.
#define UINT_FMT "%u"
#define INT_FMT "%d"
typedef int mp_int_t; // must be pointer size
typedef unsigned mp_uint_t; // must be pointer size
typedef long mp_off_t;
#define MP_PLAT_PRINT_STRN(str, len) mp_hal_stdout_tx_strn_cooked(str, len)
// extra built in names to add to the global namespace
#define MICROPY_PORT_BUILTINS \
    //{ MP_ROM_QSTR(MP_QSTR_open), MP_ROM_PTR(&mp_builtin_open_obj) },
// We need to provide a declaration/definition of alloca()
#include <alloca.h>
#define MICROPY_HW_BOARD_NAME "minimal"
#define MICROPY_HW_MCU_NAME "unknown-cpu"
#ifdef __linux__
#define MICROPY_MIN_USE_STDOUT (1)
#endif
#ifdef __thumb__
#define MICROPY_MIN_USE_CORTEX_CPU (1)
#define MICROPY_MIN_USE_STM32_MCU (1)
#endif
#define MP_STATE_PORT MP_STATE_VM
#define MICROPY_PORT_ROOT_POINTERS \
    const char *readline_hist[8];
My micropython.mk file for the module:
HELPERS_MOD_DIR := $(USERMOD_DIR)
# Add all C files to SRC_USERMOD.
SRC_USERMOD += $(HELPERS_MOD_DIR)/helpers.c
# We can add our module folder to include paths if needed
# This is not actually needed in this example.
#CFLAGS_USERMOD += -I$(HELPERS_MOD_DIR)
My module source:
// helpers.h
// This is our helper function
STATIC mp_obj_t helpers_c_helper(mp_obj_t op_code, mp_obj_t mp_arg1, mp_obj_t mp_arg2);
// helpers.c
#include "py/obj.h"
#include "py/runtime.h"
#include "py/builtin.h"
#include "helpers.h"
// Module usage:
// import helpers
// helpers.c_helper(a, b, c)
// Define a Python reference to the function above
STATIC MP_DEFINE_CONST_FUN_OBJ_3(helpers_c_helper_obj, helpers_c_helper);
// Define all properties of the example module.
// Table entries are key/value pairs of the attribute name (a string)
// and the MicroPython object reference.
// All identifiers and strings are written as MP_QSTR_xxx and will be
// optimized to word-sized integers by the build system (interned strings).
STATIC const mp_rom_map_elem_t helpers_module_globals_table[] = {
    { MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_helpers) },
    { MP_ROM_QSTR(MP_QSTR_c_helper), MP_ROM_PTR(&helpers_c_helper_obj) },
STATIC MP_DEFINE_CONST_DICT(helpers_module_globals, helpers_module_globals_table);
// Define module object.
const mp_obj_module_t helpers_user_cmodule = {
    .base = { &mp_type_module },
    .globals = (mp_obj_dict_t*)&helpers_module_globals,
// Register the module to make it available in Python
MP_REGISTER_MODULE(MP_QSTR_helpers, helpers_user_cmodule, MODULE_HELPERS_ENABLED);
stijn
Re: Adding External C Modules with external functions to mp as a library
Post by stijn » Wed Mar 11, 2020 8:40 am
The code you show doesn't contain a definition of helpers_c_helper, only a declaration, hence the undefined reference?
Also I don't know all effects of declaring static functions in header files, but least to say is that it's unusual and probably not intended?
cduran
Post by cduran » Wed Mar 11, 2020 1:37 pm
I updated my code as follows and still getting an undefined reference. helpers_c_helper is fully defined.
// helpers.h
//extern mp_obj_t helpers_c_helper(mp_obj_t op_code, mp_obj_t mp_arg1, mp_obj_t mp_arg2);
void set_helper_callback(mp_obj_t (*function)(mp_obj_t, mp_obj_t, mp_obj_t));
// helpers.c
#include "py/obj.h"
// Module usage:
// import helpers
// Null function
mp_obj_t do_nothing(mp_obj_t a_obj, mp_obj_t b_obj, mp_obj_t c_obj)
	return mp_obj_new_int(0);
mp_obj_t (*fun_ptr)(mp_obj_t, mp_obj_t, mp_obj_t) = &do_nothing;
	fun_ptr = function;
STATIC mp_obj_t helpers_c_helper(mp_obj_t a_obj, mp_obj_t b_obj, mp_obj_t c_obj)
    return (*fun_ptr)(a_obj, b_obj, c_obj);
stijn
Post by stijn » Wed Mar 11, 2020 3:09 pm
Aha, looks like you found a bug. I don't know why, but the culprit is defining MODULE_HELPERS_ENABLED in mpconfigport: if you remove that line and instead use CFLAGS_EXTRA=-DMODULE_HELPERS_ENABLED=1 on the commandline it works. Tried with the unix port and it doesn't have that problem though.
Post by dhylands » Wed Mar 11, 2020 4:19 pm
You should also look at the linker command line (i.e. build with make V=1).
The GNU linker has some peculiarities about the order that object files need to appear in order to resolve symbols.
So lets say you have a foo.o file which needs to call some_function and some_function is defined in bar.o
Then foo.o needs to occur on the linker command line before bar.o (or the library containing bar.o)
cduran
Post by cduran » Wed Mar 11, 2020 5:07 pm
I actually found that the libs makefile wasnt building my modules c file. I fixed the issue, however, now the c module executes when called, but when it returns from the module function the firmware hangs. Any thoughts?
cduran
Post by cduran » Wed Mar 11, 2020 5:13 pm
I basically discovered that the actual c file for the c module wasn't being compiled into the library, I edited the makefile to fix the issue.
Of course that now uncovered another issue, the c module function executes fine but hangs the firmware when it returns. Any ideas what could be wrong?
Post by dhylands » Wed Mar 11, 2020 7:46 pm
It's hard to say, especially without seeing the code. The C code is probably corrupting something (likely the stack).
I'd probably start by making the C code do nothing and just return. And then start adding functionality back in to figure out where it's messing things up.
cduran
Post by cduran » Wed Mar 11, 2020 7:52 pm
In particular this line is causing the hang, I've tried using a constant and still have a hang.
return mp_obj_new_int_from_uint(aCounter);
