Adding External C Modules with external functions to mp as a library
Posted: Tue Mar 10, 2020 11:29 pm
I have a unique problem that I am trying to solve. I'm currently building mp 1.12 as a library which I then import into my existing project. My project is arm based and has no OS so I'm using the minimal build as a start.
So far I'm able to build an mp lib and run script strings just fine. Where I'm having problems is adding a C module to the library.
I am following the instructions here, with one exception: http://docs.micropython.org/en/latest/d ... dules.html
The exception is that the only function in the module requires a lot of libraries and code from the project I am added mp to. So in my case this code:
is replaced with a header file containing
The body of this function is part of my code. The library builds with no errors, but when I build my project I get an undefined reference error for the function in my module. Any ideas, suggestions?
I've included my following
mpconfigport.h
micropython.mk
helpers.h - module code
helpers.c
Here's my Makefile for the library:
My micropython.mk file for the module:
My module source:
// This is the function which will be called from Python as example.add_ints(a, b).
STATIC mp_obj_t example_add_ints(mp_obj_t a_obj, mp_obj_t b_obj) {
// Extract the ints from the micropython input objects
int a = mp_obj_get_int(a_obj);
int b = mp_obj_get_int(b_obj);
// Calculate the addition and convert to MicroPython object.
return mp_obj_new_int(a + b);
STATIC mp_obj_t example_add_ints(mp_obj_t a_obj, mp_obj_t b_obj);
mpconfigport.h
micropython.mk
helpers.c
#include <stdint.h>
// options to control how MicroPython is built
// You can disable the built-in MicroPython compiler by setting the following
// config option to 0. If you do this then you won't get a REPL prompt, but you
// will still be able to execute pre-compiled scripts, compiled with mpy-cross.
#define MICROPY_ENABLE_COMPILER (1)
#define MICROPY_QSTR_BYTES_IN_HASH (1)
#define MICROPY_QSTR_EXTRA_POOL mp_qstr_frozen_const_pool
#define MICROPY_ALLOC_PATH_MAX (256)
#define MICROPY_ALLOC_PARSE_CHUNK_INIT (16)
#define MICROPY_EMIT_X64 (0)
#define MICROPY_EMIT_THUMB (0)
#define MICROPY_EMIT_INLINE_THUMB (0)
#define MICROPY_COMP_MODULE_CONST (0)
#define MICROPY_COMP_CONST (0)
#define MICROPY_COMP_DOUBLE_TUPLE_ASSIGN (0)
#define MICROPY_COMP_TRIPLE_TUPLE_ASSIGN (0)
#define MICROPY_MEM_STATS (0)
#define MICROPY_DEBUG_PRINTERS (0)
#define MICROPY_ENABLE_GC (1)
#define MICROPY_GC_ALLOC_THRESHOLD (0)
#define MICROPY_REPL_EVENT_DRIVEN (0)
#define MICROPY_HELPER_REPL (1)
#define MICROPY_HELPER_LEXER_UNIX (0)
#define MICROPY_ENABLE_SOURCE_LINE (0)
#define MICROPY_ENABLE_DOC_STRING (0)
#define MICROPY_ERROR_REPORTING (MICROPY_ERROR_REPORTING_TERSE)
#define MICROPY_BUILTIN_METHOD_CHECK_SELF_ARG (0)
#define MICROPY_PY_ASYNC_AWAIT (0)
#define MICROPY_PY_BUILTINS_BYTEARRAY (0)
#define MICROPY_PY_BUILTINS_DICT_FROMKEYS (0)
#define MICROPY_PY_BUILTINS_MEMORYVIEW (0)
#define MICROPY_PY_BUILTINS_ENUMERATE (0)
#define MICROPY_PY_BUILTINS_FILTER (0)
#define MICROPY_PY_BUILTINS_FROZENSET (0)
#define MICROPY_PY_BUILTINS_REVERSED (0)
#define MICROPY_PY_BUILTINS_SET (0)
#define MICROPY_PY_BUILTINS_SLICE (0)
#define MICROPY_PY_BUILTINS_PROPERTY (0)
#define MICROPY_PY_BUILTINS_MIN_MAX (0)
#define MICROPY_PY_BUILTINS_STR_COUNT (0)
#define MICROPY_PY_BUILTINS_STR_OP_MODULO (0)
#define MICROPY_PY___FILE__ (0)
#define MICROPY_PY_GC (0)
#define MICROPY_PY_ARRAY (0)
#define MICROPY_PY_ATTRTUPLE (0)
#define MICROPY_PY_COLLECTIONS (0)
#define MICROPY_PY_MATH (0)
#define MICROPY_PY_CMATH (0)
#define MICROPY_PY_IO (0)
#define MICROPY_PY_STRUCT (0)
#define MICROPY_PY_SYS (0)
#define MICROPY_MODULE_FROZEN_MPY (1)
#define MICROPY_CPYTHON_COMPAT (0)
#define MICROPY_LONGINT_IMPL (MICROPY_LONGINT_IMPL_NONE)
#define MICROPY_FLOAT_IMPL (MICROPY_FLOAT_IMPL_NONE)
#define MODULE_HELPERS_ENABLED (1)
// type definitions for the specific machine
#define MICROPY_MAKE_POINTER_CALLABLE(p) ((void*)((mp_uint_t)(p) | 1))
// This port is intended to be 32-bit, but unfortunately, int32_t for
// different targets may be defined in different ways - either as int
// or as long. This requires different printf formatting specifiers
// to print such value. So, we avoid int32_t and use int directly.
#define UINT_FMT "%u"
#define INT_FMT "%d"
typedef int mp_int_t; // must be pointer size
typedef unsigned mp_uint_t; // must be pointer size
typedef long mp_off_t;
#define MP_PLAT_PRINT_STRN(str, len) mp_hal_stdout_tx_strn_cooked(str, len)
// extra built in names to add to the global namespace
#define MICROPY_PORT_BUILTINS \
//{ MP_ROM_QSTR(MP_QSTR_open), MP_ROM_PTR(&mp_builtin_open_obj) },
// We need to provide a declaration/definition of alloca()
#include <alloca.h>
#define MICROPY_HW_BOARD_NAME "minimal"
#define MICROPY_HW_MCU_NAME "unknown-cpu"
#ifdef __linux__
#define MICROPY_MIN_USE_STDOUT (1)
#endif
#ifdef __thumb__
#define MICROPY_MIN_USE_CORTEX_CPU (1)
#define MICROPY_MIN_USE_STM32_MCU (1)
#endif
#define MP_STATE_PORT MP_STATE_VM
#define MICROPY_PORT_ROOT_POINTERS \
const char *readline_hist[8];
HELPERS_MOD_DIR := $(USERMOD_DIR)
# Add all C files to SRC_USERMOD.
SRC_USERMOD += $(HELPERS_MOD_DIR)/helpers.c
# We can add our module folder to include paths if needed
# This is not actually needed in this example.
#CFLAGS_USERMOD += -I$(HELPERS_MOD_DIR)
// helpers.h
// This is our helper function
STATIC mp_obj_t helpers_c_helper(mp_obj_t op_code, mp_obj_t mp_arg1, mp_obj_t mp_arg2);
// helpers.c
#include "py/obj.h"
#include "py/runtime.h"
#include "py/builtin.h"
#include "helpers.h"
// Module usage:
// import helpers
// helpers.c_helper(a, b, c)
// Define a Python reference to the function above
STATIC MP_DEFINE_CONST_FUN_OBJ_3(helpers_c_helper_obj, helpers_c_helper);
// Define all properties of the example module.
// Table entries are key/value pairs of the attribute name (a string)
// and the MicroPython object reference.
// All identifiers and strings are written as MP_QSTR_xxx and will be
// optimized to word-sized integers by the build system (interned strings).
STATIC const mp_rom_map_elem_t helpers_module_globals_table[] = {
{ MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_helpers) },
{ MP_ROM_QSTR(MP_QSTR_c_helper), MP_ROM_PTR(&helpers_c_helper_obj) },
STATIC MP_DEFINE_CONST_DICT(helpers_module_globals, helpers_module_globals_table);
// Define module object.
const mp_obj_module_t helpers_user_cmodule = {
.base = { &mp_type_module },
.globals = (mp_obj_dict_t*)&helpers_module_globals,
// Register the module to make it available in Python
MP_REGISTER_MODULE(MP_QSTR_helpers, helpers_user_cmodule, MODULE_HELPERS_ENABLED);
