linking with `round` for the pyboard
v923z
Post by v923z » Thu Mar 19, 2020 10:46 am
Hi all,
I have attempted to add the around function to ulab, and to that end, I call math's round as MICROPY_FLOAT_C_FUN(round) https://github.com/v923z/micropython-ul ... ise.c#L156 . This works on the unix port, but I can't compile for the pyboard, and get a linker error
LINK build-PYBV11/firmware.elf
arm-none-eabi-ld: build-PYBV11/code/vectorise.o: in function `vectorise_around':
vectorise.c:(.text.vectorise_around+0x76): undefined reference to `roundf'
make: *** [Makefile:582: build-PYBV11/firmware.elf] Error 1
I have tried to add the linker flag in the Makefile, but that doesn't help at all. What bugs me is the fact that the other math functions can be linked, and I don't see, why roundf should be any more special.
Can someone shed some light on the problem?
Thanks,
Zoltán
Re: linking with `round` for the pyboard
Post by jimmo » Fri Mar 20, 2020 2:54 am
Can you explain what you mean by that... you should just need to add roundf.c to SRC_LIBM. (It seems to work for me).
v923z
Post by v923z » Fri Mar 20, 2020 8:16 am
I added -lm to the linker flags.
That solved it, thanks!
However, I haven't yet found a way of appending to a make variable on the command line. All solutions I have seen so far rely on changing the makefile itself, which I want to avoid. I hope it doesn't sound selfish, but I would really like ulab to be a standard, drop-in user module that one can compile without having to change anything in micropython.
Post by jimmo » Fri Mar 20, 2020 8:50 am
That tells the compiler to use its libm.a -- which we don't want.
Great, I think you should send a PR to add this unconditionally. (The linker will throw it away if it's unused).
Not at all, it's exactly the right thing to aim for.
In this case I think the limitation is as described above - MicroPython should have had this in the sources list anyway. Setting a linker flag isn't what you want.
But yes, if you did need to set a linker flag from your C module makefile, then if that's not currently possible then it would be worth sending a PR to make it possible. I will take a look later.
v923z
Post by v923z » Mon Mar 23, 2020 9:42 am
OK, I'll update the makefiles, and send a PR.
v923z
Post by v923z » Tue Mar 24, 2020 7:19 am
Jim, as requested, I have modified the makefiles, and issued a PR: https://github.com/micropython/micropython/pull/5789
