SPI Basics - Custom Board
Posted: Fri May 08, 2020 9:00 pm
I have ported micropython to my board based around an STM32F767 chip, and am having trouble getting SPI working.
I have enabled SPI4 in my `mpconfigboard.h`file:
and also in the pins.csv file I have defined the correct pins for my board:
I am able to write to the SPI4 pins easily enough using the Pin class, but when I try to send something using SPI the pins do not change at all. My SPI python code is simple:
I am watching the lines on a logic analyser, so I know they're not toggling. <=== This is wrong (see below)
It turns out that I was looking at the wrong place in the logic analyser - once I had the triggereing setup properly SPI4 comes up clear as day. Woops!
Any clues on where to look? Hopefully it's my python and not the firmware...
Edit: Found my problem; keeping this on the forum for others' benefit.
#define MICROPY_HW_SPI4_NSS (pin_E4)
#define MICROPY_HW_SPI4_SCK (pin_E2)
#define MICROPY_HW_SPI4_MISO (pin_E5)
#define MICROPY_HW_SPI4_MOSI (pin_E6)
D34,PE5
D35,PE6
D36,PE4
D37,PE2
SPI4_NSS,PE4
SPI4_SCK,PE2
SPI4_MISO,PE5
SPI4_MOSI,PE6
from pyb import SPI
s = SPI(4)
s.init(SPI.MASTER, 1000000)
s.send(b'hello')
