Encoder in Hardware with Timer Peripheral
Re: Encoder in Hardware with Timer Peripheral
Post by OutoftheBOTS_ » Mon Jun 15, 2020 9:02 pm
MartinManzinger wrote:
Mon Jun 15, 2020 9:55 am
I put a schmitt trigger in front of every button and encoder signal I have. So for me it's the perfect solution now. It's maybe a good idea to put a example code into the wiki?
I am curious if a schmitt trigger will work to remove switch bounce as the signal bounces all the way from total open to totally closed.
I know the hardware bounce filter I linked above uses a cap and resistor to slow the charging and discharging on the cap to remove the bounce
