here is the C code I wrote for Timer:
STATIC mp_obj_t timer_start(mp_uint_t n_args, const mp_obj_t *args) {
enum { ARG_self, ARG_duration, ARG_callback, ARG_type };
timer_obj_t *self = args[ARG_self];
uint32_t duration = mp_obj_get_int(args[ARG_duration]);
if (!MP_OBJ_IS_FUN(args[ARG_callback]) && (args[ARG_callback] != mp_const_none))
mp_raise_ValueError("Error function type");
uint8_t type = mp_obj_get_int(args[ARG_type]);
if (type == TIMER_PERIODICAL)
gtimer_start_periodical(&(self->obj), duration, mp_obj_timer_irq_handler,
self); // MBED api that controls timer
else if (type == TIMER_ONESHOT)
gtimer_start_one_shout(&(self->obj), duration, mp_obj_timer_irq_handler,
else
mp_raise_ValueError("Invalid TIMER type");
self->callback = args[ARG_callback];
return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(timer_start_obj, 4, 4, timer_start);
And write a timer handler called “mp_obj_timer_irq_handler” as such,
void mp_obj_timer_irq_handler(timer_obj_t *self) {
if (self->callback != mp_const_none) {
gc_lock();
nlr_buf_t nlr;
if (nlr_push(&nlr) == 0) {
mp_call_function_0(self->callback);
nlr_pop();
} else {
self->callback = mp_const_none;
mp_printf(&mp_plat_print, "Uncaught exception in callback handler");
if (nlr.ret_val != MP_OBJ_NULL)
mp_obj_print_exception(&mp_plat_print, (mp_obj_t)nlr.ret_val);
gc_unlock();
>>> from machine import Timer
>>> t = Timer(0) # Create a timer obj on timer 0
>>> t.init() # init it
>>> t.start(2000000, lambda x: print(”test”), t.PERIODICAL) # period at 2s, callback only print, trigger periodically
It looks and works all good until the last line of the script where I started the timer and then it gets stuck and cannot exit until I manually reset the hardware.
After some trial and error, it appears to me that my C handler never even gets trigger when I pass the python lambda function into the API as an argument
It will mean tremendously to me if someone can give me some suggestions on what is going wrong with my code and how to correctly trigger another handler inside a handler, thanks!
