Doc change pull requests languishing
stijn
Re: Doc change pull requests languishing
Post by stijn » Fri Oct 09, 2020 7:40 am
In general I think these contributions are worth it. However (left a github comment as well) none of the commit messages adhere to the coding standards, only the Pull requests titles do. So I'd suggest you change that: if it cannot be merged as-is, it's more than twice the work for the maintainer. And that's likely the main reason these aren't merged: lack of time. Also perhaps create one single commit where you fix typos instead of x commits where only one word changes.
hlovatt
Post by hlovatt » Fri Oct 09, 2020 10:00 pm
stijn
Post by stijn » Sat Oct 10, 2020 11:57 am
I'm editing directly on GitHub and it doesn't seem to have that ability.
Ah that's too bad. Might be less work to work locally from a fork then push.
Post by deshipu » Sun Oct 11, 2020 7:39 am
I don't think anybody is going to look at them as long as they are failing the tests.
