External C module in Pumbaa
JosefPeter
Post by JosefPeter » Mon Nov 23, 2020 7:30 pm
Hi everybody,
I use Pumbaa in Platformio and it is great thing. But I failed to include a external C module.
In my project I need to generate sine waves with up to 30 kHz on the Dac and measure the amplitude and phase with the Adc.
That´s only possible in an external C module what I want to call in MicroPython.
Has anybody experience with including external C code in Pumbaa?
And does anybody of you know how to generate the file "qstrdefs.generated.h" &"qstrdefs.preprocessed.h" ?
Thank you for helping me!!!!
Josef
Re: External C module in Pumbaa
Post by jimmo » Mon Nov 23, 2020 11:39 pm
I don't know much about Pumbaa. Can you described more about how you added your C module.
In upstream MicroPython, the process is described here https://docs.micropython.org/en/latest/ ... dules.html although I suspect in order to work inside PlatformIO that Pumbaa is probably using its own build system (or a heavily modified version of MicroPython's build system).
The other thing is that (unless I'm looking in the wrong place) Pumbaa seems to have not been updated for a long time and in particular is based on a four-year old version of MicroPython.
This is described in http://docs.micropython.org/en/latest/develop/qstr.html
It's...not straightforward, but hopefully those docs give you a starting point where to look in the MicroPython makefiles to see how this is done.
