Link to class methods in composition technique
ales.coppelli
Post by ales.coppelli » Wed Dec 23, 2020 11:07 am
I have a STM32F411 board and when I try to use
the I2C bus master is all ok:
from machine import I2C
i2c = I2C(1)
i2c.scan() -->Ok [25,30][i.e. address of accelerometer, address of magnetometer]
i2c.writeto_mem(25,32,b'\x77')
i2c.writeto_mem(25,35,b'\x08')
i2c.readfrom_mem(25,40,1)
i2c.readfrom_mem(25,41,1)
Now I would like to write ( in C ) a class for my project that use an I2C object
i.e. I would like write something like this ( in Micropython interpreter):
from MYMODULE_WROTE_IN_C import MYCLASS_WROTE_IN_C
i2c = I2C(1)
a = MYCLASS_WROTE_IN_C(i2c)
and now the object 'a' should be use the object 'i2c'
(composition technique )
Question:
How I can use/run/invoke the class methods ( 'writeto_mem' e 'readfrom_mem' )
from a method in MYCLASS_WROTE_IN_C ?
This is what I did.
The definition of my class is:
typedef struct _myclass_obj_t {
mp_obj_base_t base;
struct _machine_hard_i2c_obj_t* i2c;
} myclass_obj_t;
and in the constructor of my class I verify the correct type
if (mp_obj_get_type(args[0]) == &machine_hard_i2c_type) {
self->i2c=args[0];
}else{
mp_print_str(MP_PYTHON_PRINTER, "The argumet is not a I2C type.");
and the compilation is ok.
But when I write something like
self->i2c->machine_i2c_writeto_mem(25,35,0x08);
I obtain the compilation error:
error: dereferencing pointer to incomplete type 'struct _machine_hard_i2c_obj_t'
If I write in the file "myclass_wrote_in_c.c"
//From ports/stm32/machine_i2c.c
typedef struct _machine_hard_i2c_obj_t {
mp_obj_base_t base;
i2c_t *i2c;
mp_hal_pin_obj_t scl;
mp_hal_pin_obj_t sda;
} machine_hard_i2c_obj_t;
I obtained the correct error:
error: 'struct _machine_hard_i2c_obj_t' has no member named 'writeto_mem'
What do I do to invoke a class methods that belongs to object 'i2c' ?
