serialize memoryview
ttmetro
Post by ttmetro » Mon Jan 18, 2021 3:19 am
I'm working on an msgpack serializer for micropython written in C.
Python bytes objects map to the msgpack bin type and serializing those works fine.
Now I would like the packer also to handle memoryviews of bytes (and bytearray) objects and wonder how to do this. Memoryviews are defined in in py/objarray.[hc]. One option is to detect memoryviews with type BYTEARRAY_TYPECODE or MICROPY_PY_BUILTINS_BYTEARRAY and then directly access the mp_obj_array_t.
It this the correct approach or does a more appropriate api exist?
Bernhard Boser
Re: serialize memoryview
Post by jimmo » Mon Jan 18, 2021 4:47 am
When you serialise them, do you care about the distinction between memoryview and bytearray/bytes?
The reason I ask is that for any type, then if it's not something you directly handle (int, str, iterable), then calling mp_get_buffer will just give you back a buffer for any bytes-like type that you can directly serialise.
ttmetro
Post by ttmetro » Mon Jan 18, 2021 5:44 pm
... calling mp_get_buffer will just give you back a buffer for any bytes-like type that you can directly serialise.
Perfect! I'm glad I asked.
Stupidly, I already used mp_get_buffer, but restricted it to bytes only.
Bernhard Boser
