Compiling for a personalized card STM32F407VGT6
Krasn4ck
Post by Krasn4ck » Wed Feb 10, 2021 6:45 pm
Hello.
I am trying to compile MicroPython version 1.14 on a custom board with STM32F407VGT6, I have all the compile files needed to compile are as follows:
  • mpconfigboard.h
  • mpconfigboard.mk
  • pins.csv
  • stm32f4xx_hal_conf.h
I put the folder of these files in the path /ports/stm32/boards/ but I get the following error when I try to compile:
make: *** No rule to make target 'build-OPHYRA/genhdr/pins.h', needed by 'build-OPHYRA/py/mpstate.o'.  Stop.
This is the command I am using to perform the compilation:
make -j2 BOARD=OPHYRA
I am using Cygwin to perform the compilation process
Thank you very much if you can give me any guidance as to what the problem is with this error.
Update, now have this issue:
 make BOARD=OPHYRA
CC machine_adc.c
In file included from machine_adc.c:29:
adc.h: In function 'adc_deselect_vbat':
adc.h:50:29: error: 'LL_ADC_PATH_INTERNAL_VBAT' undeclared (first use in this function)
   50 |         adc_common->CCR &= ~LL_ADC_PATH_INTERNAL_VBAT;
adc.h:50:29: note: each undeclared identifier is reported only once for each function it appears in
make: *** [../../py/mkrules.mk:77: build-OPHYRA/machine_adc.o] Error 1
Re: Compiling for a personalized card STM32F407VGT6
Post by jimmo » Thu Feb 11, 2021 5:22 am
How did you fix the first issue?
Are you able to successfully build other boards? For example the OLIMEX_F407 is a good test as it uses the same MCU.
Krasn4ck
Post by Krasn4ck » Thu Feb 11, 2021 5:11 pm
Hi Jimmo with OLIMEX_F407 I had no problem, now I simply corrected this error, but now I got this one:
CC build-OPHYRA/frozen_content.c
LINK build-OPHYRA/firmware.elf
C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-ld.exe: build-OPHYRA/main.o: in function `stm32_main':
main.c:(.text.stm32_main+0x264): undefined reference to `_sstack'
C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-ld.exe: build-OPHYRA/stm32_it.o: in function `HardFault_C_Handler':
stm32_it.c:(.text.HardFault_C_Handler+0x150): undefined reference to `_sstack'
C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin\arm-none-eabi-ld.exe: build-OPHYRA/modmachine.o: in function `machine_info':
modmachine.c:(.text.machine_info+0x1a0): undefined reference to `_sstack'
make: *** [Makefile:689: build-OPHYRA/firmware.elf] Error 1
Post by jimmo » Fri Feb 12, 2021 2:15 am
Can you put a copy of the OPHYRA board directory somewhere (e.g. on github) ?
