Startup: Reset_Handler and simila ( STM32F411-DISCO Arm Cortex-M4)
ales.coppelli
Post by ales.coppelli » Mon Feb 15, 2021 4:54 pm
Hi to all.
I'm trying to undestand the early stages after a power on in a
STM32F411-DISCO ( Arm Cortex-M4 ).
Immediatly after a reset ( or power on ) the program counter is
setting at 0x00000004 and called "Reset_Handler"
This function is in 'micropython/ports/stm32/resethandler.s'
... At the end ...
    /* Initialise the system and jump to the main code */
    bl   SystemInit
    mov  r0, r4
    b    stm32_main
So, from Reset_Handler we have to jump ( with a return ) to "SystemInit".
Question_1
Where is this function?
I saw only a comment in 'micropython/ports/stm32/system_stm32.c'
but no implementation.
  *   This file provides two functions and one global variable to be called from
  *   user application:
  *      - SystemInit(): This function is called at startup just after reset and
  *                      before branch to main program. This call is made inside
  *                      the "startup_stm32.s" file.
  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
  *                                  by the user application to setup the SysTick
  *                                  timer or configure other parameters.
Question 2
Then we have to jump (without return ) to "stm32_main":
'ports/stm32/mboot/main.c' or 'ports/stm32/main.c' ?
Which one ?
Re: Startup: Reset_Handler and simila ( STM32F411-DISCO Arm Cortex-M4)
Post by dhylands » Mon Feb 15, 2021 6:10 pm
The best way to answer this is to look in the .map file produced by the linker when it runs. For example, after doing
make BOARD=STM32F411DISC
you'll find a firmware.map in the build-STM32F411DISC directory.
Searching for SystemInit, you'll see:
 .text.SystemInit
                0x0000000008052fa8       0x4c build-STM32F411DISC/lib/stm32lib/CMSIS/STM32F4xx/Source/Templates/system_stm32f4xx.o
                0x0000000008052fa8                SystemInit
This tells us that the .o file was from lib/stm32lib/CMSIS/STM32F4xx/Source/Templates/system_stm32f4xx.o which means that you'll find the .c file in micropython/lib/stm32lib/CMSIS/STM32F4xx/Source/Templates/system_stm32f4xx.c
Similarly, for stm32_main:
 .text.stm32_main
                0x000000000804a5ec      0x284 build-STM32F411DISC/main.o
                0x000000000804a5ec                stm32_main
which tells us it's coming from ports/stm32/main.c, and not insdie the mboot directory. The stm32_main from mboot would be the entry point if you installed the mboot bootloader, but that's normally not the case on the STM32F4 series.
ales.coppelli
Post by ales.coppelli » Tue Feb 16, 2021 7:12 am
Thank you very much!!!
