How read dump logs type: panic.
prem111
Post by prem111 » Sat Feb 27, 2021 3:14 pm
Sorry for the obvious question for you. How to read dump panic'ed logs? Thanks.
Re: How read dump logs type: panic.
Post by dhylands » Sat Feb 27, 2021 9:24 pm
You can use a tool like rshell (or ampy or thonny) and cat the file.
Or you can write some code in python to read the file.
If pyboard.py works with your board, you could do something like this:
with open('/flash/panic.log', 'r') as logfile:
    for line in logfile:
        print(line)
and put that in a file on your local machine and then execute it on your board using pyboard,py
