Driver for WS2812 RGB LEDs (NeoPixels, ...)
torwag
Re: Driver for WS2812 RGB LEDs (NeoPixels, ...)
Post by torwag » Tue Feb 07, 2017 8:09 am
Beside of deshipus comment,
many sources on the net state that you should use some resistors and blocking capacitors in front of the first LED since they tend to be quite easily harmed by voltage spikes. Honestly, speaking I never did this and did not kill a single LED yet. Just wanted to mention.
Also take into account that the 3.3 V logic level might seems to be sufficient on the test-bench but the 3 m wire from the controller to the LED-stripe in the final application might create a lot of head-scratching ;)
Hmmm. thinking more about it, I wonder if the logic-level theory fits... since, if the first LED only receives rubbish digital values, it just forwards digital rubbish at now 5V to the other LEDs. However, I remember to read that the level shifters in the LED are more forgiving then other parts of the LED circuitry. Ultimately, I guess deshipu is right to say it would be much better to adapt the logic level.
deshipu
Post by deshipu » Tue Feb 07, 2017 11:38 am
My sources:
https://hackaday.com/2017/01/25/ws2812b ... originals/
http://hackaday.com/2017/01/20/cheating ... data-line/
Re-reading this again, I agree that it doesn't quite add up in my theory -- it's probably some kind of a timing problem.
calyerm
Post by calyerm » Mon Nov 20, 2017 4:28 pm
After looking with logic analyzer on data line , the timing does not appear to be correct. The baudrate clock is good but the
neopixel bit low and high pulse widths are not right. For this clock (baudrate is actually 262500) Need 1/4 ratio for neopixel bit low and 2/2 ratio for neopixel bit high. Correction: Thats 2/4 ration for high.
cefn
Post by cefn » Sat Nov 25, 2017 12:58 pm
@calyerm what was your configuration (software/hardware) when you ran the logic analyser?
Were you using https://github.com/JanBednarik/micropython-ws2812 as per the original post viewtopic.php?f=5&t=394#p2199
cefn
Post by cefn » Sat Nov 25, 2017 1:01 pm
matto
Post by matto » Mon Mar 05, 2018 9:51 pm
Hi all!
I'd like to ask you about this library. I can see it's a little outdated, but it might still work for my needs:
I have a VERY long strip of WS2813 LEDs (1100 of them) in my ceiling. Right now I'm using an Arduino Mega with the FastLed library to drive them, and while it works, it has a VERY low frame rate. What I'd like to do is to drive them with an STM32 like this running MicroPython:
https://www.aliexpress.com/item/STM32-S ... 71346.html
Do you think this will improve the FPS of the animations? Are this library and microcontroller suited for this task?
Thanks!
mathieu
Post by mathieu » Wed May 23, 2018 2:28 pm
Damien wrote:
Wed Dec 10, 2014 11:49 pm
fma wrote:Great! But as I understand from your post on the other thread, the call to send() is still blocking during transfert, so CPU is not availabe for other tasks. Am I right?
Right. First step was to get DMA working, and main reason for that was to get uninterrupted transfers with interrupts enabled. Previously send() was disabling interrupts during a transfer, and this can lead to lost interrupts. Now it's much better with DMA, even if you have to wait for it to finish.
Next step will be to have an option to return before transfer is compete. And some function to check completion, as well as a callback.
May I ask what the state of SPI.send() is in 1.9.4? Did someone eventually implement the option to return before transfer is compete?
