$ font_to_py.py --help
from machine import SoftI2C, Pin
import ssd1306
OLED_SCL_PIN = 22 # clock
OLED_SDA_PIN = 21 # data
OLED_WIDTH = 128 # pixels
OLED_HEIGHT = 32 # pixels
def oled_text_scaled(oled, text, x, y, scale, character_width=8, character_height=8):
# temporary buffer for the text
width = character_width * len(text)
height = character_height
temp_buf = bytearray(width * height)
temp_fb = ssd1306.framebuf.FrameBuffer(temp_buf, width, height, ssd1306.framebuf.MONO_VLSB)
# write text to the temporary framebuffer
temp_fb.text(text, 0, 0, 1)
# scale and write to the display
for i in range(width):
for j in range(height):
pixel = temp_fb.pixel(i, j)
if pixel: # If the pixel is set, draw a larger rectangle
oled.fill_rect(x + i * scale, y + j * scale, scale, scale, 1)
def main():
i2c = SoftI2C(scl=Pin(OLED_SCL_PIN), sda=Pin(OLED_SDA_PIN))
oled = ssd1306.SSD1306_I2C(OLED_WIDTH, OLED_HEIGHT, i2c)
# no scaling
oled.fill(0)
oled.text("ABCDEFGHIJKLMNOP", 0, 0)
oled.text("abcdefghijklmnop", 0, 8)
oled.text("0123456789012345", 0, 16)
oled.text("=!\"#$%&/()?-+*:;", 0, 24)
oled.show()
time.sleep(3)
# 2x
oled.fill(0)
oled_text_scaled(oled, "ABCDEFGH", 0, 0, 2)
oled_text_scaled(oled, "abcdefgh", 0, 16, 2)
oled.show()
time.sleep(3)
# 4x
oled.fill(0)
oled_text_scaled(oled, "ABCD", 0, 0, 4)
oled.show()
time.sleep(3)
if __name__ == "__main__":
main()
Done, do you want me to remove the previous post's content and just put a link to the solution on GitHub?davef wrote: ↑Mon Dec 09, 2024 6:57 pmI suggest posting this here:
https://github.com/orgs/micropython/dis ... w-and-tell
