I have posted a project using ESP-Now in a water tank level monitoring system at
https://github.com/davefes/ESP-Now-repeater. It uses a float switch as a simple
level alarm. As ESP-Now can send small data packets, it's over to you to do
something more fancy.
The main feature of this implementation is using the ESP32 as an ESP-Now repeater
to cater for a long obstructed path.
Thanks to glenn20 for his work on the ESP-Now protocol and guidance on some
aspects of the SW implementation.
