With the RSSI capability in the ESPNow v1.18 versions of the ESP32 at:
https://github.com/glenn20/micropython- ... g24cf16719
I have posted at:
https://github.com/davefes/ESPNow-Range-Testing
a sender and receiver application using a display OLED to give 5 second updates of RSSI.
ESPNow range/antenna testing (RSSI)
Re: ESPNow range/antenna testing (RSSI)
Thank you. Are these python scripts only compatible with ESPNOW? Or we can test ESP32-WROOM etc. too?
You can already test RSSI on the standard ESP32 variants with v1.18.
I should made it clearer that I was talking about v1.18 of the ESPNow images at:
for example.
rssi = sta_if.status('rssi')
print (str(rssi))
for example.
Thanks a lot for the clarification again.
