https://github.com/glenn20/micropython- ... /issues/20
I nominated the local end (receiver) to operate in AP-mode and the sender end (transmitter) in STA-mode. Whether or not other configurations work has not been investigated by me.
Remember the mac address is different between STA and AP modes. Also, note the use of the ifidx parameter when specifying peers.
e0.add_peer(local_mac, ifidx=network.STA_IF)
# sender.py for ESPNow LR-mode testing.
from esp import espnow
import utime
CYCLE_TIME = 60 # seconds
REBOOT_DELAY = 5 # seconds
#local_mac = b'\x08:\xf2\xab\xe2\x0c' # STA-mode
local_mac = b'\x08:\xf2\xab\xe2\r' # AP-mode
pin33 = Pin(33, Pin.OUT)
pin33.off()
def reboot(delay = REBOOT_DELAY):
# print a message and give time for user to pre-empt reboot
# in case we are in a (battery consuming) boot loop
print (f'Rebooting device in {delay} seconds (CTRL-C to escape).')
# or just machine.deepsleep(delay) or lightsleep()
utime.sleep(delay)
machine.reset()
print ('you have 5 seconds to do Ctrl C if you want to edit the program')
utime.sleep(5)
w0 = network.WLAN(network.STA_IF)
w0.active(True) # has to be true before the following line
w0.config(protocol=network.MODE_LR)
print (w0.config('mac'))
e0 = espnow.ESPNow()
# these functions generate exceptions on error - always return None
e0.init()
e0.config(timeout = CYCLE_TIME * 1000)
except KeyboardInterrupt as err:
raise err # use Ctrl-C to exit to micropython repl
except Exception as err:
print ('Error initialising espnow:', err)
reboot()
# heartbeat, this also slows the loop down
pin33.on()
utime.sleep_ms(150)
pin33.off()
utime.sleep_ms(150)
pin33.on()
utime.sleep_ms(150)
pin33.off()
status = 'we have a link'
# if you want to save more battery, set sync=False
# at cost of not knowing if message was received.
e0.send(local_mac, status, True)
utime.sleep(10)
print ('Error during execution:', err)
reboot()
# receiver.py for ESPNow LR-mode testing.
import utime
import ssd1306_peter_hinch
i2c = SoftI2C(scl=Pin(5), sda=Pin(4), freq=100000)
display = ssd1306_peter_hinch.SSD1306_I2C(128, 64, i2c)
remote_mac = b'x!\x84{\xde\x80' # STA-mode
#remote_mac = b'x!\x84{\xde\x81' # AP-mode
print (f'Rebooting device in {delay} seconds (Ctrl-C to escape).')
utime.sleep(delay)
machine.reset()
print ('you have 5 seconds to do Ctrl-C if you want to edit the program')
utime.sleep(5)
w0 = network.WLAN(network.AP_IF)
w0.active(True) # has to be True before the following
e0.init()
e0.config(timeout = (CYCLE_TIME) * 1000)
e0.add_peer(remote_mac, ifidx=network.AP_IF)
reboot()
print ('waiting for a msg from the remote')
for mac, msg in e0:
if mac == remote_mac:
msg = msg.decode('utf-8')
print (msg)
break # out of the for loop!!
elif mac == None:
print ('no peers found')
utime.sleep(5)
break
print ('Recv from {}: "{}"'.format(mac, msg))
utime.sleep(5)
break
rssi_time_ms = (e0.peers[b'x!\x84{\xde\x80'])
rssi = (rssi_time_ms[0])
print (rssi)
# display the RSSI
display.fill(0)
display.text(f'RSSI = {rssi:.0f}' + 'dBm', 0, 24)
display.show()
# all other exceptions cause a reboot
reboot()
LR mode in both the sender and the receiver.
I would appreciate any comments about whether or not I have used the idifx parameter correctly or any other potential errors in my approach.
