Light printer
Posted: Mon Jun 16, 2014 9:53 pm
Playing around with a micropython board and some Adafruit "Neopixel" LEDs to make a light printer.
It's not very sophisticated as yet. I tried to key the updates to the accelerometer, but it turned out I got more consistent results just updating at a constant rate.
wsled.py (based on code by Markus Gritsch http://forum.micropython.org/viewtopic.php?f=2&t=149):
lightprinter.py:
main.py:
I am having a lot of fun with this board
def _set_bit(b, mask):
return b | mask
def _clear_bit(b, mask):
return b & ~mask
def _set_bit_for_boolean(b, mask, val):
if val:
return _set_bit(b, mask)
return _clear_bit(b, mask)
class WSLedChain(object):
def __init__(self, bus, length):
self.bus = bus
if isinstance(self.bus, int):
from pyb import SPI
self.bus = SPI(self.bus, SPI.MASTER, baudrate=3200000, polarity=0, phase=1)
self.bus.send(chr(0x00))
self.length = length
# Each LED requires three pieces of color data, and each color requires
# 4 bytes for the SPI transfer.
self._data = bytearray(3 * length * 4)
self._initialize_data()
def _initialize_data(self):
for index in range(self.length):
self.set_color(index, (0, 0, 0))
def refresh(self):
self.bus.send(self._data)
def _set_data(self, index, byte):
mask = 0x80
for bit in range(0, 8, 2):
bit1 = (0x1 if (byte & (mask >> bit) == 0) else 0x3)
bit2 = (0x1 if (byte & (mask >> (bit + 1)) == 0) else 0x3)
self._data[index + (bit//2)] = bit1 << 4 | bit2
def _get_data(self, index):
mask = 0x80
byte = 0
bit_data = self._data[index + (bit//2)]
bit1 = bit_data >> 4
bit2 = bit_data & 0x0f
byte = _set_bit_for_boolean(byte, mask >> bit, bit1==0x3)
byte = _set_bit_for_boolean(byte, mask >> (bit + 1), bit2==0x3)
return byte
def set_color(self, index, color):
base_index = index * 12
self._set_data(base_index, color[1])
self._set_data(base_index + 4, color[0])
self._set_data(base_index + 8, color[2])
def get_color(self, index):
return (self._get_data(base_index + 4), self._get_data(base_index), self._get_data(base_index + 8))
from wsled import WSLedChain
x = (255, 80, 100)
_ = ( 0, 0, 0)
z = ( 80, 0, 255)
y = ( 60, 255, 60)
o = ( 0, 0, 0)
hi_py_data = (
(o,o,o,o,),
(_,_,_,_,),
(x,x,x,x,),
(_,x,_,_,),
(x,x,x,x,),
(_,_,_,_,),
(x,x,x,_,),
(_,_,_,_,),
(_,_,_,_,),
(_,_,_,_,),
(y,y,y,y,),
(_,y,_,_,),
(_,y,y,y,),
(z,z,z,z,),
(_,z,_,z,),
(_,_,z,_,),
(_,_,_,_,),
(_,_,_,z,),
(_,_,z,_,),
(z,z,_,_,),
(_,_,z,_,),
(_,_,_,z,),
(_,_,_,_,),
(o,o,o,o,),
def light_print(chain, data, time):
pyb.delay(500)
index = 0
for index in range(len(data)):
for p_index, pixel in enumerate(data[index]):
chain.set_color(p_index, pixel)
chain.refresh()
pyb.delay(time//len(data))
def start_printer(bus, data, time):
chain = WSLedChain(bus, 4)
sw = pyb.Switch()
pyb.wfi()
if sw():
import lightprinter
lightprinter.start_printer(2, lightprinter.hi_py_data, 1000)
