Library for HC-SR04 and SRF04 ultrasonic sensors
SkG
Post by SkG » Fri Jul 04, 2014 7:18 am
Hi all!
Now I've received my ultrasonic sensors (the previous one died, so I orderer two new) I tested my lib for it :)
So here it is if anyone is interested on it: https://github.com/skgsergio/Micropytho ... rasonic.py
At the moment it only allows one sensor but I plan to make an object that could be initialized with the two pins for each sensor (till 15th July I'm kinda busy).
mithru
Re: Library for HC-SR04 and SRF04 ultrasonic sensors
Post by mithru » Wed Aug 20, 2014 11:19 am
Hi Sergio,
I've updated your code to allow more than one sensor. I've made a pull request to your github project page.
I've tested this with two HR-SR04 sensors (added that as example code in the pull request). Do have a look and let me know if something's not working.
My fork of your project is available here: https://github.com/mithru/MicropythonLibs
If you think the update is fine, please do accept the pull request.
EDIT: For the benefit of anyone else reading this looking for the updated library, Sergio has merged the update. The library now features the following:
- multiple sensors accepted
- returns values in cm / inches
Final working library available here (with an example):
https://github.com/skgsergio/MicropythonLibs
gcarver
Post by gcarver » Sun Oct 26, 2014 4:27 am
I got my HC-SR04 working thank you very much. However I did have to make a change. I found that if there was nothing withing about 15 inches of the sensor I would end up in an endless loop waiting for the echo value to go to 0. I added a loop limit of 1000 iterations and that fixed the deadlock.
Also of note. I was using x1 and x2 for echo/trig but that would cause pyb.delay() to lockup. I switched to x7 and x8 and that fixed the problem.
End of line...
