Module for DHT22 temperature/humidity sensor
br0t
Re: Module for DHT22 temperature/humidity sensor
Post by br0t » Wed Dec 06, 2017 10:16 am
I have found your library while searching for a solution, thanks for sharing it. I will give the AM2320 a try!
br0t
Post by br0t » Fri Dec 08, 2017 8:58 am
I am getting results back from the AM2320 sensor using your library :)
However it is very unstable, e.g. for measuring every 10 seconds this is a typical result:
32.7,
0.0,
32.0,
0.0,
32.0,
0.0,
32.0,
0.0,
32.0,
[Errno 110] ETIMEDOUT
First value is temperate, second is humidity. So the temperature sometimes gives m 0 degrees which is obviously wrong. And then at some point I only get back the timeout error there. @mcauser: Any ideas what I could do to make this more stable/reliable? I tried reinitializing the sensor everytime before measuring, but that did not improve anything yet. Also tried another sensor thinking the first was borked, but no changes.
nikhiledutech
Post by nikhiledutech » Wed Jan 10, 2018 7:02 am
I need help with my code. i am currently interfacing DHT22 with STM32F407dic board and displaying its O/P asynchronously on 16x2 LCD.
But always i get "Checksum error". Kindly help me with this code. I have seen other drivers available drivers, some are using Timers for counting interval. But i am using utime module for providing us delay
Below is my code:
#Write a program to interface temp and humidity Sensor and display data on LCD
#Temperature & Humidity Driver File
from pyb import Pin,LED
import utime as time
import uasyncio as asyncio
from alcd import LCD, PINLIST
lcd = LCD(PINLIST,cols=16)
#Pin Configuration
def DHT22_PinConfig(mode): #Mode : Pin.IN, Pin.OUT or Pin.OUT_PP
sig = pyb.Pin('PC6',Pin.PULL_UP)
sig.init(mode)
#Sensor Initialisation
def DHT22_Init():
DHT22_PinConfig(Pin.IN) #Input mode
#Reading data
async def DHT22_read():
led1= pyb.LED(1)
led2= pyb.LED(2)
led3= pyb.LED(3)
led4= pyb.LED(4)
for secs in range(20, -1, -1):
DHT22_Init()
pyb.delay(2000)
lastHumidity1 = lastHumidity2 = 0
lastTemperature1 = lastTemperature2 = 0
i = j = retryCount = 0
currentTemperature = currentHumidity = checkSum = 0
csPart1 = csPart2 = csPart3 = csPart4 = 0
bitTimes = bytearray(41)
for x in range (41):
bitTimes[x] = 0
# Pin needs to start HIGH, wait until it is HIGH with a timeout
while (sig.value() == False): #exit on DHT22 return 'High' Signal within 250us
if retryCount > 125 :
lcd[0] = "DHT22 Bus Busy!"
lcd[1] = " "
await asyncio.sleep(1)
retryCount+=1
time.sleep_us(2)
#" Send the activate pulse
# * Step 1: MCU send out start signal to DHT22 and DHT22 send
# * response signal to MCU.
# * If signal is high-voltage-level, it means DHT22 is not
# * working properly, please check the electrical connection status. """
DHT22_PinConfig(Pin.OUT_PP) #Set pin to transmit data
sig.value(0) #MCU sends Start singnal on DHT22
time.sleep_ms(18) #18ms delay
sig.value(1) #MCU Pull Up
time.sleep_us(40) #40us delay
DHT22_PinConfig(Pin.IN) #Set pin to recieve data
#Find the start of the ACK Pulse
retryCount = 0
while (sig.value() == True): #Exit on DHT22 pull low within 40us
if (retryCount > 40):
lcd[0] = "DHT22 Not "
lcd[1] = "Responding"
retryCount+=1
time.sleep_us(1)
time.sleep_us(80) #DHT pull up ready to transmit data
#* Reading the 5 byte data stream
#* Step 2: DHT22 send data to MCU
# * Start bit -> low volage within 50us (actually could be anything from 35-75us)
# * 0 -> high volage within 26-28us (actually could be 10-40us)
# * 1 -> high volage within 70us (actually could be 60-85us)
for i in range (5): #5 Bytes
for j in range (8): #8 bits
retryCount = 0
while (sig.value() == False): #Exit on DHT22 pull low within 40us
if (retryCount > 75):
led4.toggle()
lcd[0] = "DHT Timeout!"
lcd[1] = "Waiting for Data"
retryCount+=1
time.sleep_us(1)
time.sleep_us(40) #Waiting for 40us
if (sig.value() == True):
bitTimes[i*8+j] = 1 #If pin is still high, bit value is a 1
else :
bitTimes[i*8+j] = 0 #The bit value is a 0
count = 0
while (sig.value() == True & count < 100):
time.sleep_us(1)
count+=1
DHT22_PinConfig(Pin.OUT_PP) #Re-initalising DHT22 in O/P mode
sig.value(1)
#Now bitTimes have the actual bits that were needed to find the end of each data bit
currentHumidity = currentTemperature = checkSum = 0
#First 16 bits is Humidity
for i in range (16):
if (bitTimes[i+1] > 0):
currentHumidity |= ( 1 << (15-i))
#Second 16 bits is Temperature
if (bitTimes[i+17] > 0):
currentTemperature |= ( 1 << (15-i))
#Last 8 bits is checksum
for i in range (8):
if (bitTimes[i+33] > 0):
checkSum |= (1 << (7-i))
# lcd[0] = 'CS{}'.format(checkSum) #Checksum values read are 028-192-224-240-252
# lcd[1] = ''
# await asyncio.sleep(1)
lastHumidity1 = currentHumidity/10
lastHumidity2 = currentHumidity%10
#If first bit of currentTemperature is 1, it is negative value.
if ((currentTemperature & 0x8000)== 0x8000):
lastTemperature1 = ((currentTemperature & 0x7FFF) / 10) * -1;
lastTemperature2 = currentTemperature % 10
# lcd[0] = 'Temp1{}'.format(lastTemperature1)
# lcd[1] = 'Temp2{}'.format(lastTemperature2)
lastTemperature1 = currentTemperature / 10.0
#Calculate Check Sum
csPart1 = currentHumidity >> 8
csPart2 = currentHumidity & 0xFF
csPart3 = currentTemperature >> 8
csPart4 = currentTemperature & 0xFF
#Checksum value read above in data frame and the addition of cspart1:4 &0xFF are not same, which is causing problem.
if (checkSum == ((csPart1 + csPart2 + csPart3 + csPart4) & 0xFF)):
lcd[0] = 'T1{}'.format(lastTemperature1) # 1870.5
lcd[1] = 'T2{}'.format(lastTemperature2) # 25-27
lcd[0] = 'Checksum error' # 1870.5
## pyb.delay(500)
loop.run_until_complete(DHT22_read())
So it means data packets are getting lost.
So please help me with your valuable inputs and help me with this code.
mcauser
Post by mcauser » Wed Jan 10, 2018 10:48 am
Please don't post the exact same message in multiple boards
